106 Timing Belt
Post Reply
Ho Chi Minger
My Cars:
106 Timing Belt
Post by Ho Chi Minger »
Is it possible to change the timing belt on a peugeot 106 (TU1engine}without the peugeot tensioning tool as mentioned in the manual.I ask because DIY the job is relatively simple and cheap[:)],whereas taking it to a peugeot garage isn't[:(].
JohnD
(Donor 2022)
My Cars: 2010 Citroen C5-X7 tourer
1998 Citroen Saxo 1.5D
2018 Citroen C4-B7
1998 Peugeot 306. 1.9D
2011 Citroen C1
x 72
Contact:
Post by JohnD »
My guess would be that lots of garages fit belts without using the recommended Pug/Cit tensioner. They rely on experience - and by turning the tensioned belt with finger and thumb through 90 degrees.
np
My Cars:
Contact:
Post by np »
I`ve changed a few belts on Renaults where the manual says that you need the tool.Never used 1 & never had any probs.
As JohnD says above,get the belt on and tightend,then use finger and thumb.
macaroni
My Cars:
Post by macaroni »
I have changed the timing belt on my 205 tu3s engine several times and, as is said above, just using the common belt tension practices will be OK; turn the belt through 90 degrees and no more and leaving about 5mm of free play in the longest stretch of belt should do.
arry_b
My Cars:
Contact:
Post by arry_b »
You may even find that the dealers tension checking tool wont reach the belt when the engine is in the car!
It's a scam by the main dealers to get you back there to get the job done "properly" (ahem!).
Post Reply
