build details
deepfat
build details
How do I get the build details for my Picasso vin VF7**************[VIN obfuscated, can be read by forum staff] will it show first reg details dealer etc.
- x 6950
Re: build details
No: This is a factory build sheet and tells you what your vehicle is fitted with from factory and other relevant information. It will show the exact build date (RPO), which, in your case is 11th February 2014. Registration dates are irrelevant and relatively meaningless, because vehicles can be made a year earlier and sat at the factory car park for example, but late registered - which is why the build date is so important. There is nothing here regarding the dealership as they are nothing to do with the specifications of the vehicle.
Here is your build sheet as requested.
| Vehicle Characteristics | |
| Vehicle Family | C3 PICASSO |
| AS/RP N° | 13609 76 1 0420 |
| Warranty Start Date | 19/03/2014 |
| Engine serial number | 10 JBFM 0067028 |
| OPB | E008 |
| BER | e2*2001/116*0371*23 |
| P4A | 9802314899 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | CITROEN |
| VEHICLE FAMILY | C3 PICASSO |
| SILHOUETTE | FAMILY SALOON |
| TRIM LEVEL | HIGH MEDIUM |
| ENGINE | TURBO DIESEL DV6DTED |
| TRANSMISSION | LONG 5-SPEED MANUAL GEARBOX |
| PAINT TYPE | METALLIC PAINTWORK |
| BODY COLOUR | KTP - SHARK GREY PAINT |
| INTERIOR TRIM TYPE | WARP AND WEFT BRISE+OMNI REPS "6D" |
| UPHOLSTERY COLOUR | "FX" |
| GEARBOX (CHARACTERISTICS) | BE4-5L MANUAL GEARBOX |
| DEFINITION TO FOLLOW | MID-LIFE |
| ENGINE (TYPE) | DV TYPE ENGINE |
| OTHER BADGE, " MISC. " | EXCLUSIVE |
| SPEEDOMETER DRIVE | W/O TACHO TORQUE |
| Fuel Supply-Engine | |
| FUEL SUPPLY | DIRECT EXCHANGER TURBO INJECTION |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| FUEL | DIESEL GRADE DA/DE/DE+ |
| EMISSIONS STANDARD (ENGINE) | EURO 5 L6 UPPER ENGINE EMISSION CONTROL |
| FUEL TANK | FUEL TANK WITH LOCATING TAB |
| COOLING MOTOR | RADIATOR TH : 18 - 21 DM2 BRAZED ALUMINIUM |
| CRANKCASE GAS CIRCUIT HEATING | WITH HEATER CASING GAS CIRCUIT |
| DEVICE (ANTIPOLLUTION) | "EGR" EXHAUST GAS RECYCLING |
| VEHICLE TECHNICAL DEPOLLUTION | TECHNICAL VEHICLE EMISSION CONTROL EURO 5 |
| PARTICLE FILTER | WITH PARTICLE EMISSION FILTER |
| FAN | 1 AERO 2-SPEED 140W FAN WITH SCOOP |
| TANK FILTER | WITHOUT RESERVOIR FILTER |
| STOP AND START | WITHOUT STOP AND START |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | REAR AXLE HYPOID GEARSET 17 X 61 |
| WHEEL STYLE | 16 INCH BLADE WHEEL |
| DIFFERENTIAL (GEARBOX) | DIFFERENTIAL 84 |
| RIM/TYRE SIZE | 16 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 195/55 R16 91T REINFORCED TYRE |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| GEARBOX TYPE | GEARBOX BE4R |
| Suspension-Steering-Brakes | |
| SUSPENSION | NORMAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | WITHOUT ELECTRONIC STABILITY PROGRAM |
| BRAKE ASSOCIATED VARIANT | ABS TEVES MK100A |
| Body Fittings | |
| HORNS | HORN STANDARD |
| AERIAL | SHORT ROOF AERIAL |
| FINISHER (SELF-ADHESIVE) | GLOSS BLACK REAR SURROUND TRIM |
| SIDE MOULDINGS (TYPE) | SIDE TRIM BODY COLOURED + CHROME |
| WHEEL EMBELLISHER (STYLE) | WITHOUT WHEEL CAP |
| UNDERBODY SHIELD | PLASTIC PROTECTIO + FOAM UNDER ENGINE |
| INDICATORS | LUMINOUS SIGNATURE |
| EXT. REARVIEW MIRROR COMP. FUNCTION | EXT MIRROR ELECTRIC-FOLD BACK |
| ENGINE BAY SOUNDPROOFING | BONNET SOUNDPROOFING |
| WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
| FRONT PANEL BLANK | FRONT FACE LOWER CLOSER |
| ROOF GLASS | WITHOUT ROOF WINDOW |
| BUMPER | FR + REAR BUMPER STD BC + CHROME TRIM |
| LUGGAGE RACK | MOUNTING WITH ROOF BARS |
| FRONT FOGLAMP | FRONT FOG LIGHTS |
| SPARE WHEEL | WITHOUT SPARE WHEEL |
| EXTERIOR ACCESSORIES | PAI/CHRO EXT HANDLES + BOD COL/CHRO NUM PLATE TRIM |
| BUMPER TRIM | BODY COLOUR BUMPER STRIP |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED WINDOW GLASS |
| Interior Fittings | |
| CIGAR LIGHTER | WITHOUT CIGAR-LIGHTER |
| REAR SEAT ARMREST | WITH REAR SEAT ARMREST |
| REAR SEATBELT | REAR 3-POINT 3 INERTIA REEL SEAT BELT |
| FRONT SEATBELT | DOUBLE PYROTECHNIC SEAT BELT WITH ALARM |
| CLIMATE (AMBIENT TEMP) | TEMPERATE COUNTRIES |
| CHILD LOCK | ELECTRIC REAR CHILD LOCK |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| GEAR SELECTOR | FLOOR GEAR CONTROL |
| DRIVING POSITION | RIGHT HAND DRIVE |
| LOAD SPACE LIGHTING | WITHOUT ARRANGING LIGHTING |
| BOOT AND LOAD SPACE LIGHTING | BOOT + LOAD SPACE + AMV LIGHTING AUTO CONTROL |
| DASHBOARD EQUIPMENT | "SOFT" PAINT EFFECT DASHBOARD EQUIPMENT |
| MISC. INT. LAMPS | FRONT SPOTLAMP + LED |
| WORK TABLE | WITH WORK TABLE |
| LOAD SPACE TRIM | CARPET BOOT MAT+CARPET SIDES |
| CHILD SEAT ANCHORING POINTS | WITHOUT CHILD SEAT MOUNTING WITH ISO RR |
| LOUDSPEAKER | ASSEMBLY 2 FR SPEAKERS + 2 RR SPEAKERS |
| RADIO CONTROLS | REMOTE RADIO CONTROL |
| FRONT PASSENGER SEAT FOLDING | FRONT SEAT FULL UPRIGHT FOLDING |
| FRONT SEAT ARMREST | FRONT SEAT CENTRAL ARMREST |
| STOWAGE BIN | FLAPS IN FLOOR |
| SATELLITE NAVIGATION SYSTEM | WITHOUT NAVIGATION SYSTEM |
| REAR WINDOW LIFT | ELECT CONTR RR WINDOW LIFTER + LOCK SYSTEM |
| PASSENGER’S WINDOW LIFT | SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER |
| DISPLAY | DISPLAY (RADIO+CLOCK,T°,CD) |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | THORAX SIDE + CURTAIN AIRBAG |
| FOOTWELL LIGHTING | DRIVER’S + FRONT PASS’S FOOTWELL LIGHTING |
| EQUIPMENT PACK | W/O EQUIPMENT PACK |
| EXTERIOR REAR VIEW MIRROR (HEATED) | HEATED DOOR MIRROR |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| INTERIOR DOOR CONTROL (APPEARANCE) | CHROME EFFECT DOOR HANDLE + COLOURED TRIM |
| STORAGE (DRIVING POSITION) | CENTRAL STORAGE COMP + LOWER STORAGE COMP |
| RADIO RECEIVER | AUDIO CD SYSTEM RDS "RD45" MP3 |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | REGULATOR AND SPEED LIMIT |
| INTERIOR REAR VIEW MIRROR | ELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR |
| LOAD SPACE STORAGE | WITH BOOT TIDY |
| TUNER RADIO | MONO RADIO TUNER |
| OBSTACLE DETECTION SYSTEM | REAR RADAR OBSTACLE SENSOR |
| LATERAL BLINDS | SIDE BLINDS "ROW 2" |
| TRIM ADAPTATION | G/LEVER KNOB LEATHER CHROME INSERT |
| FLOOR MAT | W/O CARPETMAT |
| RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
| LOCKING CONTROL | CENTRAL DEAD LOCKING |
| STEERING WHEEL | LEATHER STEERINGWHEEL |
| DRIVER’S KNEE AIRBAG | WITHOUT DRIVER’S KNEE AIRBAG |
| CHILD OBSERVATION INTERIOR MIRROR | INTERIOR CHILD MONITORING MIRROR |
| AUDIO PACK AUXILIARY SOCKET | 1 JACK SOCKET + USB |
| TELEMATIC UNIT | WITHOUT TELEMATIC UNIT |
| Electrical | |
| ALTERNATOR | ALTERNATOR 150 AMP |
| BATTERY | BATTERY L2 640 60AH EF 640 EN |
| STARTER MOTOR | STARTER MOTOR CL 4 |
| SPECIAL LIGHTING | AUTOMATIC HEADLAMP ILLUMINATION |
| BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
| Component Manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| RADIO HEADPHONE SOCKET | DOUBLE ACCESSORY SOCKET |
| REFRIGERANT | WITHOUT REFRIGERANT LIQUID |
| EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
deepfat
Re: build details
Thank you for the comprehensive build list, it's got a NI reg and I wondered if that was from new, being a complete idiot I didn't think of looking in the service book DOH!
Tastikras
Re: build details
Hi! Can I get mine c5 factory equipment sheet? Just retrofited light pack (doors pockets, leds under dashboard, rear leds under front seats) and now I planning to do audio upgrade but stuck about my original fitted equipment, because It depends what I need to change as I saw even rt6 was few variations.. I would greatly appreciate your help. VIN: VF7**************[VIN obfuscated, can be read by forum staff]
Reason: Deleted unnecessary Quote
- x 6950
Re: build details
@Tastikras
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
