1} Does anyone know the Fuel pressure regulator supply voltage, I am reading 2.85V on mine with 1-2 ohms?
2} When ignition is on Radio and Aircon don't work, but dashboard dials work for about 3 seconds then switch off, static dashboard lights stay on.
When engine is turned over the radio and aircon work but the car wont start, get error codes P2148 Fuel Injector Group A Supply Voltage High and P1366 P1367 P1368 P1369- four
Injector fault codes
Fuel pressure regulator voltage
- x 6946
Re: Fuel pressure regulator voltage
I think you'll have to go into Diagbox and look at the live data under the engine ECU as this is supplying the high pressure fuel pump. It should give you the supply voltage and the reference value.
The other codes P1366 to P1369 are saying the injector voltage is too low, which makes sense considering the main fault above is showing them as all jammed shut. So there definitely looks like a supply issue.
| Fault Code: | P2148 |
| Description of Fault: | Injector bank 1: Short circuit. Short circuit. The fault appears at the end of 200 ms. The 4 injectors are jammed shut. |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
BKS
- (Donor 2021)
Forgot to mention, no high pressure fuel at the HP port, which is why I was querying voltage at the pressure regulator, the fuel exits through the return port
- x 6946
I don't have voltages for the individual components, sorry.
