Abs Sensor Fault (C1330) C5 X7
somethingSome
x 4
Unread post by somethingSome »
Hello,
I'm having intermittent issues with one of the abs sensors (increasing in frequency now), dash shows abs and esp lights and lexia reports C1330 for the front right sensor. I figure it's just the sensor going bad, I replaced those in my other vehicles and it's usually a pretty straight forward job. However with the C5 it doesn't seem to have an intermediate connector and I have to get the plug up into the engine bay and into the BSM box.
Is this true or is there an intermediate connector for the abs sensor? Can anyone provide the steps/tips on how to do this on a C5 X7 (2009)?
x 1056
Re: Abs Sensor Fault (C1330) C5 X7
Unread post by wheeler »
Cant remember the exact position of the sensor connector but normally the front ones are in the engine bay by the inner wing.
Dont think I’ve ever seen one in the BSM box. When you get the new sensor the length of the wiring on it will give you an idea. Just follow the cabling on the original sensor
somethingSome
x 4
I got around to changing the sensor. The right side sensor was near the wing, just by the expansion tank. I'm leaving a couple of pictures, it might help someone out.
The sensor comes into the engine bay by an opening near the expansion tank.
It attaches to the connector at the wing. The abs sensor cable runs under the expansion tank.
It's pretty straight forward to remove the sensor, it's only held by a screw, however I had to remove the wheel trim so I could reach the opening into the engine bay.
Running the new sensor is pretty straight forward, just run the cable and push the plastic bits into their proper fittings. I also had to remove the bracket shown in the picture.
As a side note, I still can't find the left sensor, it's either under the BSI box or jammed somewhere it's not supposed to, so I just left it alone.
x 6946
Thanks for posting the images, bound to help others.
