Ay up!
I have ABS problems! However, when I tried to use my LEXIA to figure out the problem, LEXIA threw a tantrum and would not work. This is when I discovered that the laptop had deleted all the files that worked the interwebby thing!
I have tried reinstalling Windows 7 but it refuses to recognise the wireless card. I've bought new LEXIA software but can't authorise it. I've tried a dongle and installed the software that came with that. No dice. LEXIA will not,load on Win 10.
The computer is in serious danger of feeling the underside of my BIG hammer.
Can anyone help?
Please?
I'd Like Otterchops on the road, not decorating the drive!
LEXIA woes.
Xantianut
- x 127
LEXIA woes.
C5 HDi 110 SX (Fifi 7 or Otterchops)
RIP
Citroen Xantia 1.8i LX (Fifi 6)
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
RIP
BX19DTR (Fifi 2)
Armidillo
- x 274
Re: LEXIA woes.
As I have recently learned, late versions of Diagbox (PP2000 & Lexia) will run on 64 bit Windows, but I am guessing that your version of Lexia, like mine, will only run on 32 bit Windows.
Presumably your copy of Windows 7 was 32 bit, and the Windows 10 that you have installed is 64 bit. You can check this as follows:
1) Open Windows Explorer (now called File Explorer - press Window key & E)
2) Right click on "This PC" (which will be close to the bottom of the list of folders etc. in the LH column)
3) Select "Properties" - this should bring up "System > About"
4) Under "Device specifications" you should find "System type" which will tell you whether you have a 32 or 64 bit OS.
The modern way of resolving this is to run a copy of 32 bit Windows in a virtual machine. I have held onto an old laptop which has Windows XP (32 bit) installed. It just runs Lexia & PP2000, and never goes on the Internet, so has no need of anti-virus software, and there is no risk of my copies of "the software" trying to update themselves from PSA/Stellantis servers and getting clobbered.
Marc (& others no doubt) will explain where you can get the modern stuff...
Re: LEXIA woes.
I had that virtual machine set up on my Windows 10 64bit laptop, came from Jim at easydiagnostics.Armidillo wrote: 25 Jun 2024, 01:35 As I have recently learned, late versions of Diagbox (PP2000 & Lexia) will run on 64 bit Windows, but I am guessing that your version of Lexia, like mine, will only run on 32 bit Windows.
Xantianut
- x 127
Re: LEXIA woes.
Thanks for your help on this.
After goooooooogling "Virtual Machine" I was none the wiser
Tell ya, me and technology do NOT get on!
I,did find my old Toshiba laptop which it did run on. Bad news? Ol' Tosh will not run without a working battery. £12 I,reckon for a new one is reasonable!!
Onwards and upwards.
I'm going to cuddle my hammer......
RIP
BX19DTR (Fifi 2)
RIP
BX19DTR (Fifi 2)
Armidillo
- x 274
Re: LEXIA woes.
My battery's not much chop either - don't you have a long extension cord? Mind you, 12 quid for a laptop battery sounds OK!!
Xantianut
- x 127
Re: LEXIA woes.
Ay up!
Sitrep.
Windows Vista machine is 32 bit and won't talk to my ancient iPhone.
Bought an XP machine. 32 bit and will NOT talk to iPhone.
Windows 10 will talk to iPhone but is 64 bit.
Can anyone,help? My guesses seem to,be wrong this time.....
Sitrep.
RIP
BX19DTR (Fifi 2)
RIP
BX19DTR (Fifi 2)
- x 1481
Re: LEXIA woes.
Why do you need your Lexia/Diagbox PC to talk to your phone?
Note that at least XP does not support WPA2 wifi encryption out-of-box, this could be your problem.
Coney
- x 9
Re: LEXIA woes.
I just re-installed my Lexia software on a Win 10 - after Jim said it could be done - and it works fine. I didn't go beyond V 7.52, however.
cit-rotti
- x 78
Re: LEXIA woes.
The terms LEXIA and DIAGBOX are always mixed up. The good old LEXIA 345 with the latest update 348 can only be unlocked/activated on XP with the corresponding programme and works with vehicles up to approx. 2009. For Peugeot there is the PP2000. It is a 16-bit system.
Many people talk about the LEXIA although they mean Diagbox.
The Diagbox up to 7.xx contains the software for newer Citroen and Peugeot vehicles and additionally the LEXIA 348 + modifications and the PP2000 for older Citroen/Peugeot.
To make full use of this, a 32-bit system containing 16-bit is required, e.g. XP or WIN7 32-bit - WIN 10 32-bit is of course not possible. And of course only Pro versions.
The Diagbox is not a 16-bit diagnostic tool, but a 32-bit system. If you install the Diagbox 7.xx on a 64-bit system - which contains 32 bits - then the Diagbox will of course work for newer vehicles, but not for the old LEXIA/PLANET. If you only need to read out newer vehicles from 2008 onwards or vehicles not set up by PSA on DIAGBOX (e.g. C6...), you can of course install on WIN10 64 bit.
As of 9.25, PSA has converted the entire diagnostic software to a 32-bit system, so that both the newer cars (Diagbox) and the old boxes with WIN 10 or 11 64 bit can be diagnosed.
And they are all offline systems - nothing works online with the PSA hotline.
Greetings Wolfgang
Greetings Wolfgang
