2024 C4 Factory Build Sheet (Request ?)
P_P_Power
Unread post by P_P_Power »
Hi.
Having seen numerous forum posts where individuals have requested full "Factory Build Sheets" against a vehicles VIN No., would it be possible to obtain such information for my new C4 registered on 14/06/2024 ?
If such a sheet is available at this time, I will upgrade my membership to cover the costs involved (as requested), and supply my VIN No.
Here's hoping.
Geoff.
C4 Hatch 1.2 Puretech 130 Max EAT8 S/S in Elixir Red / Perla Nera Black Roof / Techno Pack.
x 6950
Re: 2024 C4 Factory Build Sheet (Request ?)
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
P_P_Power
Hi Marc "GiveMeABreak".
I have just donated to FCF as requested.
Please supply a full Factory Build Sheet for my vehicle ....
The VIN is VR7**************[VIN obfuscated, can be read by forum staff]
Thanks,
Geoff.
Geoff.
x 6950
Thanks for your Forum Donation. Factory Build Sheet as Requested:
Vehicle Characteristics
Vehicle familyC4 (C41)
AS/RP N°17360 82 1 0244
Warranty Start Date14/06/2024
Engine serial number10 XVBB 2277407
OPB00O0
BERe9*2007/46*6816*21
P4A9838066399
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPECITROEN
VEHICLE FAMILYC4 (C41)
SILHOUETTE5-DOOR SALOON
TRIM LEVELCOMMERCIAL VEHICLE LEVEL 2 PSA
ENGINEEB2ADTS UE64 1.2 L PETROL
TRANSMISSIONSTT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPEPAINTED METALLIC EXT COLOURED TRIM TYPE
BODY COLOUREVH - ELIXIR RED PAINTWORK
INTERIOR TRIM TYPEALCANTARA + ISABELLA PVC TEP "D7"
CONVERSION GUIDANCEWITHOUT CONVERSION
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)EB TYPE ENGINE
Fuel Supply-Engine
FUEL SUPPLYDIRECT EXCHANGER TURBO INJECTION
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELUNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE)EURO 6.4 ENGINE EMISSION CONTROL
EXHAUSTCRIMPED ROLLED TRANSVERSE SILENCER
CAPACITY1200 CM3
CATALYTIC CONVERTERWITHOUT CATALYST
FUEL TANKFUEL TANK WITHOUT LOCATING TAB
COOLING MOTORRADIATOR 21DM2 - EP21
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
VEHICLE TECHNICAL DEPOLLUTIONEURO 6.4 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTERWITH PARTICLE EMISSION FILTER
FAN1E 2VTS 140W AERO SHORT NOZZLE
DRIVE TRAININTERNAL COMBUSTION DRIVE TRAIN
TANK FILTERRESERVOIR FILTER INTERIOR
STOP AND STARTWITH STOP AND START STARTER
Gearbox Transmission
FINAL DRIVE RATIOFINAL DRIVE RATIO 15 X 58
WHEEL STYLE18-INCH ALLOY C41
SEAL, DIFFERENTIAL ENDNOT AFFECTED
RIM/TYRE SIZE18 INCH TYRE FITMENT
TYRE (SIZE, TYPE)195/60 R18 96H - NOT FOR DIFFICULT ROAD CONDITIONS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORINDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
GEARBOX TYPEATN8 TYPE GEARBOX
Suspension-Steering-Brakes
ABSWITH ABS BRAKES
REAR ANTI-ROLL BARREAR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
ANTI-THEFT DEVICEWITHOUT STEERING LOCK
FRONT ANTI-ROLL BARFR ANTI-ROLL BAR DIAMETER 22 HOLLOW
BRAKES (CIRCUIT)REAR DISC PROTECTOR
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
BRAKE ASSOCIATED VARIANTCONTI MK100 HSM ESP
Body Fittings
TOWBARWITHOUT TOWBAR
AERIALREAR SPOILER AERIAL + DIGITAL + GPS + GSM
FINISHER (SELF-ADHESIVE)GLOSS BLACK REAR SURROUND TRIM
SIDE MOULDINGS (TYPE)SILVER GREY SIDE PROTECTORS
EXHAUST TAILPIPEREAR RIGHT-HAND AND LEFT-HAND CHROME-PLATED EXHAUST PIPE
UNDERBODY SHIELDFRONT RIGHT AND FRONT LEFT UNDER-FLOOR LONG DEFLECTOR PROTECTION
INDICATORSLUMINOUS SIGNATURE
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
WASHER JETSTANDARD SCREEN WASH JET
EXT. REARVIEW MIRROR COMP. FUNCTIONELECTRIC FOLDING EXTERIOR MIRROR+DIODE
SPLASH SHIELDFRONT+REAR ACOUSTIC+FRONT RH EXTENSION
EXHAUST TAILPIPE TRIMW/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFINGSOUNDPROOFING UNDER BONNET + BULKHEAD + SERVO
WINDSCREEN GLASS (TYPE)STANDARD WINDSCREEN GLASS
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
BUMPERBODY COLOUR BUMPER+GRAIN BLACK FRONT/GLOSS BLACK REAR SKIRT
NUMBER PLATEWITHOUT LICENCE PLATE
FRONT FOGLAMPLED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AIDVIDEO PARK 2
SPARE WHEELWITHOUT SPARE WHEEL
EXTERIOR ACCESSORIESBODY COLOUR EXTERIOR HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)WITHOUT EXTERIOR MIRROR SPECIAL FEATURE
SUN ROOFWITHOUT SUN ROOF
BUMPER TRIMSILVER GREY FOGLAMP TRIM
GLASS (APPEARANCE)TINTED + DARK-TINTED RR WINDOW GLASS
HANDS FREE ACCESS AND STARTINGFRONT ACCESS+BOOT+CONTACTLESS STARTING
Interior Fittings
ANTI-THEFT ALARMVOLUME VARIATION+PERIMETER ANTI-THEFT ALARM-STD
REAR SEATFX ONE-PIECE REAR SEAT+2/3-1/3 FOLDING SEAT BACK
BLIND SPOT DETECTIONWITH BLIND SPOT MONITORING
REAR SEAT ARMRESTWITH REAR SEAT ARMREST
INTERIOR ALARM3-SENSOR INTERIOR ALARM
LUGGAGE COVERSHELF
REAR SEATBELT3 PYRO RETRACTORD + SEATBELT FASTENED TELL-TALE
FRONT SEATBELTREEL+FASTENING ALARM+CONSTANT PASSENGER/ACTIVE DRIVER FORCE LIMITER
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONINGWITH HEATER MATRIX+ADDITIONAL OUTLET
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GEAR SELECTORGEAR SELECTOR AT THE FLOOR AND AT THE STEERING WHEEL
GRAB HANDLESFRONT + REAR HANDLES
CONSOLEUPPER TRIM
DRIVING POSITIONRIGHT HAND DRIVE
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGGLOVEBOX+LED FRONT CONSOLE
DASHBOARD EQUIPMENTSLUSH GRAIN BLACK K+CHRM VENT.
INT. TRIM AND EQUIPMENT VARIATIONSTANDARD INTERIOR EQUIPMENT DRESSING
MISC. INT. LAMPSLESS INTERIOR LIGHT
INSTRUMENT PANEL (CHARACTERISTICS)INSTRUMENT PANEL WITH MATRIX+WHITE AMBIANCE
DOOR TRIMWITHOUT LINING
CHILD SEAT ANCHORING POINTS2 REAR ISOFIX MOUNTINGS + 2 REAR TOP TETHERS
LOUDSPEAKER5 FR SPEAKERS+2 RR SPEAKERS+1 BASS BOX
POLLEN FILTERWITH POLLEN FILTER + ACTIVATED CARBON
LANE KEEPING MANAGEMENT ASSISTANCELPA WITHOUT HIA DELEGATION
PASSENGER COMPARTMENT SOUNDPROOFINGSOUNDPROOFING FOR BULKHEAD + TUNNEL TOP RANGE
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
DRIVER SEAT CONTROLMANUAL DRIVER’S SEAT CONTROL
FRONT PASSENGER SEAT CONTROLMANUAL FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENTDRIVER’S SEAT BACK WITH ANGLE ADJUSTMENT AND LUMBAR SUPPORT
FRONT PASSENGER SEAT ADJUSTMENTWITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT
FRONT SEAT ARMRESTFRONT CENTRAL ARMREST
FRONT SEAT ARMREST (OPERATION)FRONT ARMREST MANUAL
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMCONNECTABLE NAVIGATION SYSTEM
HEADLAMP BULBSECO LED
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READERLKA STRUCTURAL EDGE
DISPLAY10-INCH COLOUR HD TOUCH SCREEN
MISC. INT. ACCESSORYPORTABLE SUPPORT
COURTESY MIRRORDRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
OIL GAUGESTD OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTDRIVER + R1 PASSENGER HEATED SEAT
FRONT LATERAL AIRBAGFRONT CHEST SIDE+REAR CHEST/HEAD CURTAIN AIRBAG
FOOTWELL LIGHTINGDRIVER + FR PASSENGER FOOTWELL LIGHTING
HEATING DUCTFRONT+REAR PILLAR+REAR VENTILATION
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
REAR LOAD FLOORWITHOUT REAR LOAD FLOOR
WIFIWITHOUT WIFI
STORAGE (DRIVING POSITION)GLOVE BOX + DRAWER
RADIO RECEIVERANALOGUE + DAB RADIO RECEIVER
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLACC3 DECEL0 + ACCEL0
DRIVER’S SEAT HEIGHT CONTROLDRIVER’S HEIGHT ADJUSTER HEIGHT ADJUSTMENT
INTERIOR REAR VIEW MIRRORELECTROCHROMATIC DAY-NIGHT INTERIOR MIRROR
STORAGE (OTHERS)PLAIN STORAGE POCKET
CARPET COVERW/O CARPETMAT
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGERETRACTABLE FLOOR STORAGE COMPARTMENT
REAR SEAT PADDINGWITHOUT RR PASSENGER DETECTION
OBSTACLE DETECTION SYSTEMFRONT/REAR/SIDE RADAR OBSTACLE DETECTOR + TRAJECTORY
TRIM ADAPTATIONWITHOUT MOULDING ADAPTATION
LOCKING CONTROLCENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEELFULL FLOWER LEATHER ST WHEEL
AUDIO PACK AUXILIARY SOCKETAUDIO PACK AUXILIARY SOCKET 1 USB TYPE C
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT
Electrical
ALTERNATORALTERNATOR CLASS 15 UHEA
BATTERYL3 760 70AH EFBC 760 BATTERY BECOMES EFBC
STARTER MOTORSTTD STARTER
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
BATTERY CHARGERWITHOUT ON-BOARD CHARGER
MULTIPLEXINGR3 ECO ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUGWITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPSAUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
CONDENSER (SPECIFICATIONS)CONDENSER 20DM2 - THICKNESS 12 CLASS 2
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
AIR CONDITIONING PIPESSTANDARD AIR CONDITIONING PIPES
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SET OF KEYSSET OF BADGE KEYS + BACK-UP KEY
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
SLAVE CONTROL UNITBSI + COM 2020
PaulC5
x 720
Unread post by PaulC5 »
I notice it does not have an exhaust catalyst but has a particle emission filter - do these block up on petrol engines as they do on a diesel ?
x 6950
The particle filter on these are like the new diesel ones in that they have no Eolys additive, but work in much the same way.
As for the catalyst, they do have one - it's just that they don't record it as in the same naming sense, but it is there and combined with the petrol particle filter.
P_P_Power
Thanks for the Build Sheet Marc.
Regarding the actual vehicle build date ... would this be coded in the AS/RP N° 17360 82 1 0244 number some how ?
No doubt at some point the actual Certificate of Conformity will arrive from Stellantis, which for my wifes C3 Aircross, contained her vehicles date of manufacture. (Presumably when it left the production line as a complete finished vehicle).
Geoff.
x 6950
Yes, the RPO is 17360, which basically means it was built on 20th May 2024.
