Hi all
I’ve got a 2011 ds3 d sport and as I was driving it lost all revs and would not restart.
The engine turns over for 2 seconds then stops trying.
The codes present are
P0016
P0087
P0500
I have checked the belt and it doesn’t appear to have snapped.
Anyone have any ideas what it could be?
Also can someone help me get the engine code for this vehicle too please?
Thank you
Ds3 d sport starting issue
- x 6957
Re: Ds3 d sport starting issue
You'll need to provide your VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Ivebrokeit
GiveMeABreak wrote: 19 Jun 2024, 19:19 You'll need to provide your VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
- x 6957
Here are the fault descriptors.
Just be aware cheap sensors are one of the biggest failure points (even new), so make sure you use a decent branded part.
| Fault Code: | P0016 |
| Description of Fault: | Synchronisation: Incoherence between the information from the engine speed sensor and the camshaft sensor. Description of the diagnostics: Loss of synchronisation between the camshaft sensor and the engine speed sensor. Conditions of activation of the diagnostics: Under starter |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0087 |
| Description of Fault: | Fuel circuit: The pressure measured in the injection rail is less than the setting. Description of the diagnostics: The measured pressure is below the reference value by more than 9% (For 1,2 seconds). Conditions of activation of the diagnostics: Engine running |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0500 |
| Description of Fault: | Intersystems CAN: Speed information incorrect or absent. Description of the diagnostics: Information not received or received invalid by the engine management ECU on the CAN |
| Symptoms: |
| Suspect Areas: |
Ivebrokeit
Thank you! Are you aware of what engine code it is fitted?
- x 1456
Do all those error codes come back if cleared?
- x 6957
Yes, this is a 9HR engine code, so a Euro 5 DV6C engine.
Ivebrokeit
Thank you mark for your help
Ivebrokeit
Yes as soon as you try to start
- x 1456
It would be worth checking the readings of the engine speed and fuel pressure in live diagnostics to get a better idea of what is going on.
