Ds3 d sport starting issue
Ivebrokeit
Unread post by Ivebrokeit »
Hi all
I’ve got a 2011 ds3 d sport and as I was driving it lost all revs and would not restart.
The engine turns over for 2 seconds then stops trying.
The codes present are
P0016
P0087
P0500
I have checked the belt and it doesn’t appear to have snapped.
Anyone have any ideas what it could be?
Also can someone help me get the engine code for this vehicle too please?
Thank you
x 6950
Re: Ds3 d sport starting issue
You'll need to provide your VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
Ivebrokeit
GiveMeABreak wrote: 19 Jun 2024, 19:19 You'll need to provide your VIN. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
x 6950
Here are the fault descriptors.
Just be aware cheap sensors are one of the biggest failure points (even new), so make sure you use a decent branded part.
Fault Code: P0016
Description of Fault: Synchronisation: Incoherence between the information from the engine speed sensor and the camshaft sensor.
Description of the diagnostics:
Loss of synchronisation between the camshaft sensor and the engine speed sensor.
Conditions of activation of the diagnostics: Under starter
Conditions for Fault to clear:
  • 10 successive starts
Downgrade Modes whilst Fault is active:
  • Irreversible deactivation of the vehicle speed curbing function
  • Reversible deactivation of the vehicle cruise control
  • Reversible deactivation of the vehicle speed limiter
  • Sending of the information "torque uncertain" on the CAN network
  • For a gearbox with engine speed regulation (automatic gearbox or piloted manual gearbox), limitation of the torque sent to the gearbox
Symptoms:
  • Starting problem
  • Absence of automatic stopping of the internal combustion engine (If the vehicle has the Stop and Start system)
Suspect Areas:
  • Camshaft position sensor
  • Camshaft pulley
  • Engine speed sensor
  • Engine speed sensor target
  • Timing belt
  • Electrical harnesses
  • Connectors
Fault Code: P0087
Description of Fault: Fuel circuit: The pressure measured in the injection rail is less than the setting.
Description of the diagnostics: The measured pressure is below the reference value by more than 9% (For 1,2 seconds).
Engine running
  • Driving for 5 minutes with several full load accelerations for 10 seconds
  • Closing of the EGR (exhaust gas recycling) valve
  • Irreversible deactivation of the vehicle speed limiter
  • Irreversible deactivation of the vehicle cruise control
  • Deactivation of taking account of the tight spot information
  • Switching of the turbocharging pressure regulation to controlled mode
  • Switching to fuel "normal reduced flow" mode
  • Switching on of the warning lamp and/or warning message Warning lamp MIL
  • Warning lamp STOP
Symptoms:
  • Jerking/stalling
  • Lack of power
  • Starting problem
  • Slightly higher fuel consumption
  • Fluid leak/smells (diesel fuel, oil, etc.)
  • Cutting of the vehicle speed limiter
  • Cutting of cruise control
  • Difficult to engage gears
  • Noise
  • Engine acceleration at wrong time
  • Smoke from the exhaust
Suspect Areas:
  • Poor quality of the fuel or type of fuel
  • Air leak on the fuel filter
  • Clogging of the fuel filter
  • Leak in fuel circuit (low pressure)
  • Blockage on the low pressure fuel return circuit
  • Fuel high pressure flow regulator
  • High pressure fuel pump
  • Pressure sensor on the fuel high-pressure injection rail
  • Leak on the high pressure fuel pipes
  • Leak on the fuel high pressure common injection rail
  • Fuel injectors
  • Connectors
Fault Code: P0500
Description of Fault:Intersystems CAN: Speed information incorrect or absent.
Description of the diagnostics: Information not received or received invalid by the engine management ECU on the CAN
  • Switching on of the warning lamp and/or warning message: Warning lamp MIL
Symptoms:
  • Jerking/stalling
  • Lack of power
Suspect Areas:
  • Engine ECU
  • Intersystem CAN network
Ivebrokeit
Thank you! Are you aware of what engine code it is fitted?
x 1481
Unread post by xantia_v6 »
Do all those error codes come back if cleared?
x 6950
Ivebrokeit wrote: 19 Jun 2024, 20:03 Thank you! Are you aware of what engine code it is fitted?
Yes, this is a 9HR engine code, so a Euro 5 DV6C engine.
Ivebrokeit
Thank you mark for your help 👍🏼
Ivebrokeit
xantia_v6 wrote: 19 Jun 2024, 20:05 Do all those error codes come back if cleared?
Yes as soon as you try to start
x 1481
It would be worth checking the readings of the engine speed and fuel pressure in live diagnostics to get a better idea of what is going on.
