Citroen C5 x7 2011 MCP
Hide91
Unread post by Hide91 »
Hey, so. I managed to break my gearbox. It ran dry on oil and now it sounds like you're pulling a metal container across the asphalt when I shift into first and drive.
That aside. I've read that these cars (Citroen C5 x7 2011, 1.6 hdi 110) comes in 6spd piloted (manual gearbox with automatic "addon"(?), manual and automatic. My question is. Since mine is a MCP piloted, can I replace the gearbox with a regular, manual one and just connect the piloted module here? or do I need the exact gearbox that I've got right now? (STT 6-SPEED PILOTED MANUAL GEARBOX)
I've also tried finding a sheet on showing me how to rebuild this gearbox, but all I could find was how to remove and refit the MCP piloted on a DV6S STT engine.
Thanks in advance.
Vin if needed
Hide91
Re: Citroen C5 x7 2011 MCP
I have a gearbox + engine of the same engine type that's been on a DS4. Its a 6 speed manual, but its been with a manual stick, so the question is if it can be connected to the piloted module(?) that makes my car an automatic in relative terms. Engine codes on the vehicle in question as well as the DS4 that the gearbox has been on is 9HR.
x 6957
No, these are specific to the engine and system. You must get the correct one as there are multiple variants.
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Hide91
Thank you.
