Part numbers/diagram for engine mounts - 2009 C5 X7?
steveclv
x 40
Unread post by steveclv »
Morning :)
Does anyone have the part numbers and maybe an exploded diagram of the engine mounts, especially the rear one on a 2009 C5 X7 138 HDI FAP please?
I'm picking up some car ramps today so I can get underneath properly and see if/what the damage I may have done when the engine dropped after changing the lhs motor mount - big oopsie.
x 2000
Re: Part numbers/diagram for engine mounts - 2009 C5 X7?
Unread post by Stickyfinger »
Steve Walsh
x 516
Unread post by Steve Walsh »
steveclv
Where in France are you
Steve
steveclv
x 40
@stickyfinger - THANK YOU so much!!
@Steve Walsh - Poitiers, Dept 86
Steve Walsh
x 516
OK, I am a couple of hours South, i have a 2 post lift in my workshop if you get stuck.
Steve
steveclv
x 40
Thanks - I'll see how I get on when I get underneath to see what's going on - otherwise I might just take you up on that :)
Thanks so much!
x 6956
steveclv wrote: 10 Jun 2024, 08:43 Morning :)
Be aware that the diagram posted above by 'Stickyfinger' is for an automatic X7 only with DW10BTED4 engine, not a manual and secondly, is 10 years out of date, so there have been some part numbers superseded.
It therefore should only be used as a guide if applicable to your specific vehicle. Some parts are no longer available either.
steveclv
x 40
Fortunately it does not appear as if there is any damage and the parts look OK. I will probably replace the rubber bushing seeing as I am doing the others. I have another couple of questions about other things I found but I will do a new post for them.
