Diagbox User Manual
steveclv
- x 40
Diagbox User Manual
Not sure if anyone needs this but as I received my box yesterday, I found this quite useful to get started.
BarryP207
- x 6
Re: Diagbox User Manual
Thank you so much! Is this the same as the Training Manual they give you on the official course do you know?
Thanks,
Barry.
Thanks,
Barry.
deepfat
Just got the hardware/software and loaded it on the PC and thought what now, did a search and up this popped, thanks for sharing and saving me from a probable nervous breakdown
againbenn
I actually need this manual. Thanks for sharing.
Rhothgar
- (Donor 2026)
- x 221
Where did this go?
Admins?
Admins?
- x 8065
Zip files have been disabled to avoid illegal posts concealed in zips
cit-rotti
- x 77
The DIAGBOX manual can be accessed in any standard Diagbox tool in all languages.
However, this workshop aid originates from the initial version of the Diagbox (V05xx) – the principle still applies, of course – but the diagnostic interface has changed several times.
Rhothgar
- (Donor 2026)
- x 221
Morgen!cit-rotti wrote: 09 Feb 2026, 10:14 The DIAGBOX manual can be accessed in any standard Diagbox tool in all languages.
Thank you. I am not familiar with Diagbox as I've only really ever used Lexia but partner's Peugeot 3008 is 2013 so I will be getting to know Diagbox for sure.
- x 8065
This is getting split into two threads which is a bit confusing but here's a link to my post on the other thread which is now locked.
viewtopic.php?p=861414#p861414
cit-rotti
- x 77
This information (user manual) can also be accessed in offline applications.
However, this only applies up to DB V07xx, e.g. 7.57.
From version 9.xx onwards, this information is no longer available.
Where to find it:
Open DB 7.xx – the interface does not need to be connected to the DB.
Then press the arrow key at the top left or press F1.
Then press the ?/Help key – the user manual will appear in the language selected for the application.
Alternatively:
On ‘C’, open the ‘AW-Root’ folder,
then the ‘dtrd’ folder,
then the ‘doc’ folder,
then the ‘Help’ folder,
and select the PDF in the desired language there – copy it if necessary.
Where to find it:
Alternatively:
cit-rotti
- x 77
erledigt
Rhothgar
- (Donor 2026)
- x 221
Superb! Really useful info.cit-rotti wrote: 09 Feb 2026, 19:34 This information (user manual) can also be accessed in offline applications.
Where to find it:
Alternatively:
Thanks!
