DS3 Crossback build sheet
Crystalyne
x 4
Unread post by Crystalyne »
Hey all,
Looking to grab the build sheet for the following VIN number:
VR1**************[VIN obfuscated, can be read by forum staff]
Could I also get confirmation that this car has the improved battery (?) as there seems to be 2 variants of the car floating around, one with a 206 mile rated range and another with a 232 mile range.
Many thanks!
x 6950
Re: DS3 Crossback build sheet
Sure:
I can't confirm any changes to the battery, as there are no replacement (superseded) part numbers for the main traction battery - however, there is an alternative traction battery proposed where these are no longer available.
Vehicle Characteristics
Vehicle familyDS 3 CROSSBACK (D34)
AS/RP N°16742 81 1 0081
Warranty Start Date29/11/2022
Engine serial number10 5TDN 0028482
OPB00KH
BERe2*2007/46*0639*20
Traction Battery N°81280006259
General Information
PRODUCT TYPEPASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPEDS
VEHICLE FAMILYDS 3 CROSSBACK (D34)
SILHOUETTE5-DOOR CROSS OVER
TRIM LEVELUPPER MEDIUM
ENGINEELECTRIC MOTOR 100 KW 260 N/M
TRANSMISSIONAUTOMATIC WITH REDUCTION GEAR
PAINT TYPEPAINTED METALLIC EXT TRIM TYPE
BODY COLOUREHZ - BOUGAINVILLEA PAINT
INTERIOR TRIM TYPELEATHER CLAUDIA + CARLA "3U"
UPHOLSTERY COLOUR"FO"
DEFINITION TO FOLLOWINITIALE RANGE
ENGINE (TYPE)ELECTRICAL VEHICLE
OTHER BADGE, " MISC. "WITHOUT FULLER BADGE
BADGEE-TENSE
STEERINGVARIABLE POWER STEERING
Fuel Supply-Engine
DRIVE BATTERYBATTERIE DE TRACTION 50KWH 18S 1P6S NMC622 CATL
FUEL SUPPLYALIMENTATION ELECTRIQUE
DIESEL FILTER WATER DETECTORWITHOUT DIESEL FILTER WATER DETECTOR
FUELWITHOUT FUEL
EMISSIONS STANDARD (ENGINE)WITHOUT ENGINE EMISSION CONTROL
EXHAUSTWITHOUT EXHAUST
CAPACITYWITHOUT
CATALYTIC CONVERTERWITHOUT CATALYST
FUEL TANKWITHOUT FUEL TANK
FUEL TANK INSULATIONWITHOUT FUEL TANK INSULATION
COOLING MOTORRADIATOR THICKNESS 21 -26DM2
CRANKCASE GAS CIRCUIT HEATINGW/O HEATER CASING GAS CIRCUIT
SPECIAL POWER TRAIN SOUNDWITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEM"EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER
VEHICLE TECHNICAL DEPOLLUTIONELECTRICAL
PARTICLE FILTERWITHOUT PARTICLE FILTER
FAN1-SPEED FAN 170W VARIABLE DYNAMIC AIR SHUTTER
DRIVE TRAINELECTRIC DRIVE TRAIN
TANK FILTERWITHOUT RESERVOIR FILTER
STOP AND STARTWITHOUT STOP AND START
Gearbox Transmission
FINAL DRIVE RATIOFINAL DRIVE RATIO 17 X 77
WHEEL STYLE18-INCH NAMAKA WHEEL
CLUTCHWITHOUT CLUTCH
SEAL, WHEEL ENDWHEEL-SIDE SEAL RZ 17.5
SEAL, DIFFERENTIAL ENDAXLE-SIDE SEAL JB2T
RIM/TYRE SIZE18 INCH TYRE FITMENT
TYRE (SIZE, TYPE)215/55 R18 99V NON CRD
DRIVING WHEELS2 DRIVEN WHEELS
WHEEL (TYPE)ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATORINDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION
GEARBOX TYPERG1 TYPE GEARBOX
Suspension-Steering-Brakes
ABSWITH ABS BRAKES
ANTI-THEFT DEVICEELECTRIC ANTI-THEFT DEVICE
STEERING COLUMNSTEERING COLUMN IN HIGH POSITION
BRAKE TYPEVENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLEVIRTUAL CLASS 3 SENSOR
SUSPENSIONNORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEMELECTRONIC STABILITY PROGRAM
STEERING (OPERATION)ELECTRIC POWER STEERING
ELECTRIC STEERING90 AMPERES ELECTRIC STEERING
PEDAL BRACKET (TYPE)SIMPLE STANDARD PEDAL BRACKET
Body Fittings
TOWBARWITHOUT TOWBAR
HORNSHORN STANDARD
AERIALINTEGRATED AM/FM1 AERIAL + DIGITAL
REAR SPOILERASSEMBLY WITH REAR SPOILER
SIDE MOULDINGS (TYPE)LATERAL PROTECTOR MASS TINTED
SIDE MOULDINGS (DIMENSION)WITHOUT BODY SILL PROTECTORS
WHEEL EMBELLISHER (STYLE)WHITE CENTRE CAPS+CHROME BOLTS DESIGN
EXHAUST TAILPIPEWITHOUT EXHAUST TAIL PIPE
UNDERBODY SHIELDFRONT RIGHT AND FRONT LEFT UNDER-FLOOR LONG DEFLECTOR PROTECTION
SIDE REPEATER INDICATORSWITHOUT LATERAL FLASHERS
SILL ILLUMINATION LAMPWITHOUT SILL ILLUMINATION
ADDITIONAL SHIELD (UNDER ENGINE)W/O ENGINE UNDERSHELDING
WASHER JETSTANDARD SCREEN WASH JET
EXT. REARVIEW MIRROR COMP. FUNCTIONELECTRIC FOLDING EXTERIOR MIRROR+DIODE
EXHAUST TAILPIPE TRIMW/O EXHAUST OUTLET EMBELLISHER
ENGINE BAY SOUNDPROOFINGSOUNDPROOFING BULKHEAD+BONNET+SERVO+POWER TRAIN
WINDSCREEN GLASS (TYPE)STANDARD WINDSCREEN GLASS
WINDSCREEN WIPERFRONT WIPER BLADE WITH RAIN SENSOR
REAR SCREEN WIPERWITH REAR WIPER
HEADLAMP WIPERW/O HEADLAMP WIPER
REAR SCREEN WIPER (OPERATION)INTERMITTENT REAR WIPER STOPPING ON THE RIGHT
FRONT PANEL BLANKWITHOUT FRONT BUMPER PLUG
ROOF GLASSWITHOUT ROOF WINDOW
SIDE LOAD DOORWITHOUT SLIDING SIDE DOOR
BUMPERCOLOUR DYED FR GRILLE + BEAD
NUMBER PLATEWITHOUT LICENCE PLATE
LUGGAGE RACKWITHOUT ROOF BARS
FRONT FOGLAMPNO FRONT FOG LIGHTS
PANORAMIC VISUAL AIDWITH REAR PANORAMIC VISUAL ASSISTANCE VISIO PARK1
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE)HT EXT RRVW MIRROR EL INT CONTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE)OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEELWITHOUT SPARE WHEEL
EXTERIOR ACCESSORIESCHROMED EXTERNAL HANDLE
SPARE WHEEL MOUNTINGHALF WELL SPARE WHEEL SUPPORT
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS)WITHOUT EXTERIOR MIRROR SPECIAL FEATURE
SUN ROOFWITHOUT SUN ROOF
BUMPER TRIMDYED BUMPER STRIP
GLASS (APPEARANCE)TINTED + DARK-TINTED WINDOW GLASS
HANDS FREE ACCESS AND STARTINGFRONT ACCESS+BOOT+CONTACTLESS STARTING
Interior Fittings
ANTI-THEFT ALARMVOLUME + PERIMETER + LIFT
CIGAR LIGHTERWITHOUT CIGAR-LIGHTER
FRONT HEAD RESTRAINTFRONT HEADREST ADJUSTABLE
REAR SEATFX ONE-PIECE REAR SEAT+2/3-1/3 FOLDING SEAT BACK
SUPPLEMENTARY SEATWITHOUT ADDITIONAL SEAT
BLIND SPOT DETECTIONWITH BLIND SPOT MONITORING
REAR SEAT ARMRESTWITHOUT RR SEAT ARMREST
INTERIOR ALARM3-SENSOR INTERIOR ALARM
CABIN SEATWITHOUT CAB SEAT
REAR SEATBELTPYRO LAT RR SEAT BELT RETRACTOR + 3 POINT BELT
ASHTRAYWITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP)HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONINGWITH HEATER MATRIX+ADDITIONAL OUTLET
CHILD LOCKELECTRIC REAR CHILD LOCK
SPEED GRADUATIONSSPEED GRADUATION IN MPH
GEAR SELECTORFLOOR GEAR CONTROL
GRAB HANDLESFRONT+REAR HANDLES+HOOKS+RETRACTABLE
DRIVING POSITIONRIGHT HAND DRIVE
REMOTE CONTROLINSTALLATION OF BOOT REMOTE CONTROL
ADDITIONAL HEATINGWITHOUT ADDITIONNAL HEATING
MIRROR LINKWITH MIRROR LINK
LOAD SPACE LIGHTINGWITHOUT STORAGE COMPARTMENT LIGHTING EXCEPT BOOT
BOOT AND LOAD SPACE LIGHTINGBOOT + LOADING VOLUME LED AUTO LIGHTING CONTROL
DASHBOARD EQUIPMENTDASHBOARD WITH MISTRAL PVC CAPPING + GOLD DECOR
INT. TRIM AND EQUIPMENT VARIATIONSTANDARD INTERIOR EQUIPMENT DRESSING
MISC. INT. LAMPSLESS INTERIOR LIGHT
WORK TABLEWITHOUT WORK TABLE
UNDERSEAT STORAGEWITHOUT UNDER SEAT STORAGE
CHILD SEAT ANCHORING POINTSWITH CHILD SEAT MOUNTING WITH ISO FR AND RR
LOUDSPEAKERMOUNTING 2 FRONT LOUDSPEAKERS + 2 FRONT TWEETERS
RADIO CONTROLSSTEERING WHEEL AUDIO SYSTEM CONTROL
ADDITIONAL BLOWERWITHOUT ADDITIONAL PULSE
SIDE DOOR CONTROL MECHANISMWITHOUT SIDE DOOR CONTROL
POLLEN FILTERWITH POLLEN FILTER + ACTIVATED CARBON
FRONT PASSENGER SEAT HEIGHT CONTROLFRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT
DRIVER SEAT CONTROLMANUAL DRIVER’S SEAT CONTROL
FRONT PASSENGER SEAT CONTROLMANUAL FRONT PASSENGER SEAT CONTROL
DRIVER SEAT ADJUSTMENTWITHOUT DRIVER’S SEAT ADJUSTMENT
FRONT PASSENGER SEAT ADJUSTMENTWITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT
DRIVER’S SEAT FOLDINGW/O FOLDING DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDINGW/O FOLDING PASS FRONT SEATING
INT. UPHOLSTERY ELEMENTSMISTRAL INTERIOR ROOF TRIM
FRONT SEAT ARMRESTFRONT CENTRAL ARMREST
COMPACT DISCWITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEMWITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBSLED BULB
REAR WINDOW LIFTSEQENT CONTR RR WINDOW LIFTER
TRAFFIC INFORMATION READERPREVENTION+CORRECTION OF LATERAL TRAJECTORY
DRIVER’S WINDOW LIFTSEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFTSEQUEN CONTROL PASSENG FRONT WINDOW LIFTER
DISPLAYDGT10C HD SCREEN FRONT DISPLAY
CLOCKWITHOUT CLOCK
COURTESY MIRRORDRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING
OIL GAUGEW/O OIL LEVEL INDICATOR
FITTING REAR HEAD RESTRAINTMOUNT 3 REAR HEAD-REST
HEATING ELEMENTNON HEATED SEAT
FRONT LATERAL AIRBAGFR CHEST AND PELVIS SIDE AIRBAG+RR CHEST+FR/RR CURTAIN
FOOTWELL LIGHTINGFOOTWELL LIGHTING WITH LED
REAR PASSENGER PROTECTIONW/O RR PASSENGER PROTECTION
PASSENGER AIRBAGWITH AIRBAG ON PASSENGER SIDE
ADDITIONAL AIR CONDITIONINGWITHOUT ADDITIONAL AIR CONDITIONING
HEATING DUCTHEATING DUCT FRONT + REAR
EXTERIOR REAR VIEW MIRROR (HEATED)HEATED EXTERIOR MIRROR
AIRBAG DEACTIVATIONMANUAL AIRBAG DEACTIVATION
INTERIOR DOOR CONTROL (APPEARANCE)CHROME FINISH INSIDE DOOR HANDLE
REAR MOVING PANELMETAL TAILGATE
HEADLAMP HEIGHT ADJUSTERAUTOMATIC HEADLAMP ADJUSTMENT
FRONT SUN VISORDRIVER+PASSENGER SMALL MODEL SUN VISOR
WIFIWITH WIFI
RADIO RECEIVERDIGITAL CONNECTED NAVIGATION
REFRIGERATIONAUTOMATIC AIR CONDITIONING
CRUISE CONTROLPROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER
DRIVER’S SEAT HEIGHT CONTROLDRIVER’S HEIGHT ADJUSTER HEIGHT ADJUSTMENT
INTERIOR REAR VIEW MIRRORFRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
AIR CON./TEMPERATURE REGULATIONAUTOMATIC AIR CONDITIONNED MONO-ZONE
STORAGE (OTHERS)STANDARD STORAGE COMPARTMENT + SEAT BACK POCKETS
DRIVER AIRBAGDRIVERS AIR BAG
LOAD SPACE STORAGEW/O BOOT TIDY
REAR SEAT PADDINGWITHOUT RR PASSENGER DETECTION
TUNER RADIODUAL RADIO TUNER
OBSTACLE DETECTION SYSTEMFRONT-REAR RADAR OBSTACLE SENSOR
TRIM ADAPTATIONLEATHER KNOB + PVC GAITER
FLOOR MATFR + RR MATS
EQUALISER AMPLIFIERWITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCYWESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROLCENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEELFULL GRAIN LEATHER 3-SPOKE STEERING WHEEL
SEATING ASSOCIATED VARIANTVARIANT ASSOCIATED WITH HIGH SEAT POSITION
AUDIO PACK AUXILIARY SOCKET2 TYPE A USB PORTS
TELEMATIC UNITINDEPENDENT TELEMATIC UNIT 3S
Electrical
ALTERNATORWITHOUT ALTERNATOR
HORNSHORN STANDARD
BATTERYBATTERY L2 640 60AH EF 640 EN
STARTER MOTORWITHOUT STARTER MOTOR
CEN. LOCKING REM CONTROL FREQUENCY433.92 MHZ SUPER HETERODYNE
BATTERY CHARGERTHREE-PHASE 11 KW ON-BOARD CHARGER
MULTIPLEXINGR3 ECO ELECTRICAL ARCHITECTURE
ELECTRIC VEHICLE CHARGING PLUGWITHOUT VEHICLE LOAD RECOGNITION
BATTERY CHARGE MEASUREMENTBEV BATTERY CHARGE MEASUREMENT - BECB WITH DIAG 12V
LIGHTING OF LAMPSAUTO LIGHTING + ADAPTIVE SWITCHING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATIONSTANDARD
MODIF. DURING MODEL YEAR"00" MINOR INDEX
CONDENSER (SPECIFICATIONS)CONDENSER 24DM2 - THICKNESS 18
ATMOSPHERIC CONDITIONSNORMAL ATMOSPHERE
VIN PLATEEUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABELWITHOUT LABEL
RADIO HEADPHONE SOCKETSINGLE ACCESSORY SOCKET
TRAFFIC SIDEDRIVING ON THE LEFT-HAND SIDE
SET OF KEYSSET OF BADGE KEYS + BACK-UP KEY
DOOR SEALFRONT DOOR FRONT DIRT EXCLUDER SEAL+REAR DOOR LOWER
REFRIGERANTAIRCON FLUID 1234 YF
EMERGENCY EQUIPMENTPUNCTURE REPAIR KIT
SURFACE CONDITIONSGOOD TERRAIN
SPEED MONITORINGWITHOUT SPEED CHECK
SLAVE CONTROL UNITBSI + COM 2008 + POLY SOUND + CHROME DECOR
Crystalyne
x 4
Many thanks!
Okay, seems like maybe the range number being different is a red herring then, as near as I can tell there isn't any (documented) changes to the DS3 prior to it's facelift in 2023.
Could I get the build sheet for this VIN as well please?
Thanks!
x 6950
Here you go:
AS/RP N°15768 81 1 0021
Warranty Start Date29/12/2020
Engine serial number10 5TAW 0001886
OPB00KH
BERe2*2007/46*0639*07
Traction Battery N°760A0001017
General Information
BODY COLOURKTV - BLACK PEARL PAINT
INTERIOR TRIM TYPENAPPA LEATHER "4H"
UPHOLSTERY COLOUR"FJ"
ROOF (EXT. ASPECT)BODY COLOUR ROOF
BADGEE-TENSE
Fuel Supply-Engine
DRIVE BATTERYTRACTION BATTERY 50KWH 18S 2P6S NMC622 CATL
FUELWITHOUT FUEL
CAPACITYWITHOUT
TANK FILTERCITHOUT RESERVOIR FILTER
Body Fittings
HORNSHORN STANDARD
SIDE MOULDINGS (DIMENSION)WITHOUT SIDE PROTECTOR, WITH CHROME SILL
BUMPERBODY COLOUR STANDARD FR/RR BUMPER+CHROMED GRILLE
HANDS FREE ACCESS AND STARTINGFRONT ACCESS+BOOT+SMART DEVICE+HANDS-FREE STARTING
Interior Fittings
ANTI-THEFT ALARMVOLUME VARIATION+PERIMETER ANTI-THEFT ALARM-STD
CLIMATE (AMBIENT TEMP)TEMPERATE COUNTRIES
DASHBOARD EQUIPMENTPADDED LEATHER DECOR DASHBOARD
TRAFFIC INFORMATION READERPREVENTION+CORRECTION+DETECTION OF EDGE
WIFIWITH WIFI
STEERING WHEELFULL GRAIN LEATHER FULL 3-SPOKE STEERING WHEEL
Electrical
HORNSHORN STANDARD
BATTERY CHARGERSINGLE-PHASE 7 KW ON-BOARD CHARGER
ELECTRIC VEHICLE CHARGING PLUGT2 CABLE SOCKET G (UK)
BATTERY CHARGE MEASUREMENTWITH BATTERY CHARGE MEASUREMENT
Component Manufacturers[/td]
Miscellaneous
LABELWITHOUT LABEL
Crystalyne
x 4
Hey,
Last one to get the build sheet for (hopefully)!
VIN as follows:
Thanks!
x 6950
No Problem (now corrected - there were issues with Citroen's servers on that day :roll: - it took a while for services to come back up after an issue - but seems fine now, so I've replaced the data with the correct info for you. This can happen when they do certain updates and combined with local caching can exhibit this behaviour. :wink:
AS/RP N°16100 81 1 0073
Warranty Start Date07/01/2021
Engine serial number10 5TBQ 0004017
OPB00KH
BERe2*2007/46*0639*11
Traction Battery N°810B0001037
General Information
BODY COLOUREVL - PLATINUM GREY PAINT
BADGEE-TENSE
Fuel Supply-Engine
FUELWITHOUT FUEL
CAPACITYWITHOUT
Body Fittings
HORNSHORN STANDARD
Interior Fittings
WIFIWITH WIFI
Electrical
HORNSHORN STANDARD
Miscellaneous
LABELWITHOUT LABEL
Crystalyne
x 4
Weird!
The VIN should be for a DS3 Crossback - to double check, here's the VIN again, according to a VIN checker site this does match to the car.
x 6950
All sorted - see the original post above - all corrected - server issues as I had a few other problems with them on that day.
