Hey all,
Looking to grab the build sheet for the following VIN number:
VR1**************[VIN obfuscated, can be read by forum staff]
Could I also get confirmation that this car has the improved battery (?) as there seems to be 2 variants of the car floating around, one with a 206 mile rated range and another with a 232 mile range.
Many thanks!
DS3 Crossback build sheet
- x 6956
Re: DS3 Crossback build sheet
Sure:
I can't confirm any changes to the battery, as there are no replacement (superseded) part numbers for the main traction battery - however, there is an alternative traction battery proposed where these are no longer available.
| Vehicle Characteristics | |
| Vehicle family | DS 3 CROSSBACK (D34) |
| AS/RP N° | 16742 81 1 0081 |
| Warranty Start Date | 29/11/2022 |
| Engine serial number | 10 5TDN 0028482 |
| OPB | 00KH |
| BER | e2*2007/46*0639*20 |
| Traction Battery N° | 81280006259 |
| General Information | |
| PRODUCT TYPE | PASSENGER CAR |
| COMMERCIAL MARQUE/COMPONENT TYPE | DS |
| VEHICLE FAMILY | DS 3 CROSSBACK (D34) |
| SILHOUETTE | 5-DOOR CROSS OVER |
| TRIM LEVEL | UPPER MEDIUM |
| ENGINE | ELECTRIC MOTOR 100 KW 260 N/M |
| TRANSMISSION | AUTOMATIC WITH REDUCTION GEAR |
| PAINT TYPE | PAINTED METALLIC EXT TRIM TYPE |
| BODY COLOUR | EHZ - BOUGAINVILLEA PAINT |
| INTERIOR TRIM TYPE | LEATHER CLAUDIA + CARLA "3U" |
| UPHOLSTERY COLOUR | "FO" |
| DEFINITION TO FOLLOW | INITIALE RANGE |
| ENGINE (TYPE) | ELECTRICAL VEHICLE |
| OTHER BADGE, " MISC. " | WITHOUT FULLER BADGE |
| BADGE | E-TENSE |
| STEERING | VARIABLE POWER STEERING |
| Fuel Supply-Engine | |
| DRIVE BATTERY | BATTERIE DE TRACTION 50KWH 18S 1P6S NMC622 CATL |
| FUEL SUPPLY | ALIMENTATION ELECTRIQUE |
| DIESEL FILTER WATER DETECTOR | WITHOUT DIESEL FILTER WATER DETECTOR |
| FUEL | WITHOUT FUEL |
| EMISSIONS STANDARD (ENGINE) | WITHOUT ENGINE EMISSION CONTROL |
| EXHAUST | WITHOUT EXHAUST |
| CAPACITY | WITHOUT |
| CATALYTIC CONVERTER | WITHOUT CATALYST |
| FUEL TANK | WITHOUT FUEL TANK |
| FUEL TANK INSULATION | WITHOUT FUEL TANK INSULATION |
| COOLING MOTOR | RADIATOR THICKNESS 21 -26DM2 |
| CRANKCASE GAS CIRCUIT HEATING | W/O HEATER CASING GAS CIRCUIT |
| SPECIAL POWER TRAIN SOUND | WITHOUT POWER TRAIN ACOUSTICS |
| EOBD SELF-DIAGNOSIS SYSTEM | "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
| VEHICLE TECHNICAL DEPOLLUTION | ELECTRICAL |
| PARTICLE FILTER | WITHOUT PARTICLE FILTER |
| FAN | 1-SPEED FAN 170W VARIABLE DYNAMIC AIR SHUTTER |
| DRIVE TRAIN | ELECTRIC DRIVE TRAIN |
| TANK FILTER | WITHOUT RESERVOIR FILTER |
| STOP AND START | WITHOUT STOP AND START |
| Gearbox Transmission | |
| FINAL DRIVE RATIO | FINAL DRIVE RATIO 17 X 77 |
| WHEEL STYLE | 18-INCH NAMAKA WHEEL |
| CLUTCH | WITHOUT CLUTCH |
| SEAL, WHEEL END | WHEEL-SIDE SEAL RZ 17.5 |
| SEAL, DIFFERENTIAL END | AXLE-SIDE SEAL JB2T |
| RIM/TYRE SIZE | 18 INCH TYRE FITMENT |
| TYRE (SIZE, TYPE) | 215/55 R18 99V NON CRD |
| DRIVING WHEELS | 2 DRIVEN WHEELS |
| WHEEL (TYPE) | ALLOY WHEEL ASSEMBLY 1 |
| INFLATION PRESSURE LOSS INDICATOR | INDIRECT TYRE UNDER-INFLATION DETECTION WITHOUT LOCATION |
| GEARBOX TYPE | RG1 TYPE GEARBOX |
| Suspension-Steering-Brakes | |
| ABS | WITH ABS BRAKES |
| ANTI-THEFT DEVICE | ELECTRIC ANTI-THEFT DEVICE |
| STEERING COLUMN | STEERING COLUMN IN HIGH POSITION |
| BRAKE TYPE | VENTILATED FRONT DISCS/REAR DISCS |
| STEERING WHEEL ANGLE | VIRTUAL CLASS 3 SENSOR |
| SUSPENSION | NORMAL SUSPENSION |
| DYNAMIC STABILITY CONTROL SYSTEM | ELECTRONIC STABILITY PROGRAM |
| STEERING (OPERATION) | ELECTRIC POWER STEERING |
| ELECTRIC STEERING | 90 AMPERES ELECTRIC STEERING |
| PEDAL BRACKET (TYPE) | SIMPLE STANDARD PEDAL BRACKET |
| Body Fittings | |
| TOWBAR | WITHOUT TOWBAR |
| HORNS | HORN STANDARD |
| AERIAL | INTEGRATED AM/FM1 AERIAL + DIGITAL |
| REAR SPOILER | ASSEMBLY WITH REAR SPOILER |
| SIDE MOULDINGS (TYPE) | LATERAL PROTECTOR MASS TINTED |
| SIDE MOULDINGS (DIMENSION) | WITHOUT BODY SILL PROTECTORS |
| WHEEL EMBELLISHER (STYLE) | WHITE CENTRE CAPS+CHROME BOLTS DESIGN |
| EXHAUST TAILPIPE | WITHOUT EXHAUST TAIL PIPE |
| UNDERBODY SHIELD | FRONT RIGHT AND FRONT LEFT UNDER-FLOOR LONG DEFLECTOR PROTECTION |
| SIDE REPEATER INDICATORS | WITHOUT LATERAL FLASHERS |
| SILL ILLUMINATION LAMP | WITHOUT SILL ILLUMINATION |
| ADDITIONAL SHIELD (UNDER ENGINE) | W/O ENGINE UNDERSHELDING |
| WASHER JET | STANDARD SCREEN WASH JET |
| EXT. REARVIEW MIRROR COMP. FUNCTION | ELECTRIC FOLDING EXTERIOR MIRROR+DIODE |
| EXHAUST TAILPIPE TRIM | W/O EXHAUST OUTLET EMBELLISHER |
| ENGINE BAY SOUNDPROOFING | SOUNDPROOFING BULKHEAD+BONNET+SERVO+POWER TRAIN |
| WINDSCREEN GLASS (TYPE) | STANDARD WINDSCREEN GLASS |
| WINDSCREEN WIPER | FRONT WIPER BLADE WITH RAIN SENSOR |
| REAR SCREEN WIPER | WITH REAR WIPER |
| HEADLAMP WIPER | W/O HEADLAMP WIPER |
| REAR SCREEN WIPER (OPERATION) | INTERMITTENT REAR WIPER STOPPING ON THE RIGHT |
| FRONT PANEL BLANK | WITHOUT FRONT BUMPER PLUG |
| ROOF GLASS | WITHOUT ROOF WINDOW |
| SIDE LOAD DOOR | WITHOUT SLIDING SIDE DOOR |
| BUMPER | COLOUR DYED FR GRILLE + BEAD |
| NUMBER PLATE | WITHOUT LICENCE PLATE |
| LUGGAGE RACK | WITHOUT ROOF BARS |
| FRONT FOGLAMP | NO FRONT FOG LIGHTS |
| PANORAMIC VISUAL AID | WITH REAR PANORAMIC VISUAL ASSISTANCE VISIO PARK1 |
| EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) | HT EXT RRVW MIRROR EL INT CONTR |
| EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) | OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL |
| SPARE WHEEL | WITHOUT SPARE WHEEL |
| EXTERIOR ACCESSORIES | CHROMED EXTERNAL HANDLE |
| SPARE WHEEL MOUNTING | HALF WELL SPARE WHEEL SUPPORT |
| EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) | WITHOUT EXTERIOR MIRROR SPECIAL FEATURE |
| SUN ROOF | WITHOUT SUN ROOF |
| BUMPER TRIM | DYED BUMPER STRIP |
| GLASS (APPEARANCE) | TINTED + DARK-TINTED WINDOW GLASS |
| HANDS FREE ACCESS AND STARTING | FRONT ACCESS+BOOT+CONTACTLESS STARTING |
| Interior Fittings | |
| ANTI-THEFT ALARM | VOLUME + PERIMETER + LIFT |
| CIGAR LIGHTER | WITHOUT CIGAR-LIGHTER |
| FRONT HEAD RESTRAINT | FRONT HEADREST ADJUSTABLE |
| REAR SEAT | FX ONE-PIECE REAR SEAT+2/3-1/3 FOLDING SEAT BACK |
| SUPPLEMENTARY SEAT | WITHOUT ADDITIONAL SEAT |
| BLIND SPOT DETECTION | WITH BLIND SPOT MONITORING |
| REAR SEAT ARMREST | WITHOUT RR SEAT ARMREST |
| INTERIOR ALARM | 3-SENSOR INTERIOR ALARM |
| CABIN SEAT | WITHOUT CAB SEAT |
| REAR SEATBELT | PYRO LAT RR SEAT BELT RETRACTOR + 3 POINT BELT |
| ASHTRAY | WITHOUT ASHTRAY |
| CLIMATE (AMBIENT TEMP) | HOT OR WIDER TEMPERATE COUNTRY |
| AIR CONDITIONING | WITH HEATER MATRIX+ADDITIONAL OUTLET |
| CHILD LOCK | ELECTRIC REAR CHILD LOCK |
| SPEED GRADUATIONS | SPEED GRADUATION IN MPH |
| GEAR SELECTOR | FLOOR GEAR CONTROL |
| GRAB HANDLES | FRONT+REAR HANDLES+HOOKS+RETRACTABLE |
| DRIVING POSITION | RIGHT HAND DRIVE |
| REMOTE CONTROL | INSTALLATION OF BOOT REMOTE CONTROL |
| ADDITIONAL HEATING | WITHOUT ADDITIONNAL HEATING |
| MIRROR LINK | WITH MIRROR LINK |
| LOAD SPACE LIGHTING | WITHOUT STORAGE COMPARTMENT LIGHTING EXCEPT BOOT |
| BOOT AND LOAD SPACE LIGHTING | BOOT + LOADING VOLUME LED AUTO LIGHTING CONTROL |
| DASHBOARD EQUIPMENT | DASHBOARD WITH MISTRAL PVC CAPPING + GOLD DECOR |
| INT. TRIM AND EQUIPMENT VARIATION | STANDARD INTERIOR EQUIPMENT DRESSING |
| MISC. INT. LAMPS | LESS INTERIOR LIGHT |
| WORK TABLE | WITHOUT WORK TABLE |
| UNDERSEAT STORAGE | WITHOUT UNDER SEAT STORAGE |
| CHILD SEAT ANCHORING POINTS | WITH CHILD SEAT MOUNTING WITH ISO FR AND RR |
| LOUDSPEAKER | MOUNTING 2 FRONT LOUDSPEAKERS + 2 FRONT TWEETERS |
| RADIO CONTROLS | STEERING WHEEL AUDIO SYSTEM CONTROL |
| ADDITIONAL BLOWER | WITHOUT ADDITIONAL PULSE |
| SIDE DOOR CONTROL MECHANISM | WITHOUT SIDE DOOR CONTROL |
| POLLEN FILTER | WITH POLLEN FILTER + ACTIVATED CARBON |
| FRONT PASSENGER SEAT HEIGHT CONTROL | FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT |
| DRIVER SEAT CONTROL | MANUAL DRIVER’S SEAT CONTROL |
| FRONT PASSENGER SEAT CONTROL | MANUAL FRONT PASSENGER SEAT CONTROL |
| DRIVER SEAT ADJUSTMENT | WITHOUT DRIVER’S SEAT ADJUSTMENT |
| FRONT PASSENGER SEAT ADJUSTMENT | WITHOUT FRONT PASSENGER’S SEAT ADJUSTMENT |
| DRIVER’S SEAT FOLDING | W/O FOLDING DRIV FRONT SEATING |
| FRONT PASSENGER SEAT FOLDING | W/O FOLDING PASS FRONT SEATING |
| INT. UPHOLSTERY ELEMENTS | MISTRAL INTERIOR ROOF TRIM |
| FRONT SEAT ARMREST | FRONT CENTRAL ARMREST |
| COMPACT DISC | WITHOUT COMPACT DISC |
| SATELLITE NAVIGATION SYSTEM | WITH NAVIGATION SYSTEM COLOUR SCREEN |
| HEADLAMP BULBS | LED BULB |
| REAR WINDOW LIFT | SEQENT CONTR RR WINDOW LIFTER |
| TRAFFIC INFORMATION READER | PREVENTION+CORRECTION OF LATERAL TRAJECTORY |
| DRIVER’S WINDOW LIFT | SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
| PASSENGER’S WINDOW LIFT | SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER |
| DISPLAY | DGT10C HD SCREEN FRONT DISPLAY |
| CLOCK | WITHOUT CLOCK |
| COURTESY MIRROR | DRIVER+PASSENGER CONCEALABLE MIRROR WITH LED LIGHTING |
| OIL GAUGE | W/O OIL LEVEL INDICATOR |
| FITTING REAR HEAD RESTRAINT | MOUNT 3 REAR HEAD-REST |
| HEATING ELEMENT | NON HEATED SEAT |
| FRONT LATERAL AIRBAG | FR CHEST AND PELVIS SIDE AIRBAG+RR CHEST+FR/RR CURTAIN |
| FOOTWELL LIGHTING | FOOTWELL LIGHTING WITH LED |
| REAR PASSENGER PROTECTION | W/O RR PASSENGER PROTECTION |
| PASSENGER AIRBAG | WITH AIRBAG ON PASSENGER SIDE |
| ADDITIONAL AIR CONDITIONING | WITHOUT ADDITIONAL AIR CONDITIONING |
| HEATING DUCT | HEATING DUCT FRONT + REAR |
| EXTERIOR REAR VIEW MIRROR (HEATED) | HEATED EXTERIOR MIRROR |
| AIRBAG DEACTIVATION | MANUAL AIRBAG DEACTIVATION |
| INTERIOR DOOR CONTROL (APPEARANCE) | CHROME FINISH INSIDE DOOR HANDLE |
| REAR MOVING PANEL | METAL TAILGATE |
| HEADLAMP HEIGHT ADJUSTER | AUTOMATIC HEADLAMP ADJUSTMENT |
| FRONT SUN VISOR | DRIVER+PASSENGER SMALL MODEL SUN VISOR |
| WIFI | WITH WIFI |
| RADIO RECEIVER | DIGITAL CONNECTED NAVIGATION |
| REFRIGERATION | AUTOMATIC AIR CONDITIONING |
| CRUISE CONTROL | PROGRAMMABLE CRUISE CONTROL AND SPEED LIMITER |
| DRIVER’S SEAT HEIGHT CONTROL | DRIVER’S HEIGHT ADJUSTER HEIGHT ADJUSTMENT |
| INTERIOR REAR VIEW MIRROR | FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR |
| AIR CON./TEMPERATURE REGULATION | AUTOMATIC AIR CONDITIONNED MONO-ZONE |
| STORAGE (OTHERS) | STANDARD STORAGE COMPARTMENT + SEAT BACK POCKETS |
| DRIVER AIRBAG | DRIVERS AIR BAG |
| LOAD SPACE STORAGE | W/O BOOT TIDY |
| REAR SEAT PADDING | WITHOUT RR PASSENGER DETECTION |
| TUNER RADIO | DUAL RADIO TUNER |
| OBSTACLE DETECTION SYSTEM | FRONT-REAR RADAR OBSTACLE SENSOR |
| TRIM ADAPTATION | LEATHER KNOB + PVC GAITER |
| FLOOR MAT | FR + RR MATS |
| EQUALISER AMPLIFIER | WITHOUT EQUALISER AMPLIFIER |
| RADIO FREQUENCY | WESTERN EUROPE RADIO FREQUENCY |
| LOCKING CONTROL | CENTRAL DEADLOCKING + AUTOMATIC LOCKING |
| STEERING WHEEL | FULL GRAIN LEATHER 3-SPOKE STEERING WHEEL |
| SEATING ASSOCIATED VARIANT | VARIANT ASSOCIATED WITH HIGH SEAT POSITION |
| AUDIO PACK AUXILIARY SOCKET | 2 TYPE A USB PORTS |
| TELEMATIC UNIT | INDEPENDENT TELEMATIC UNIT 3S |
| Electrical | |
| ALTERNATOR | WITHOUT ALTERNATOR |
| BATTERY | BATTERY L2 640 60AH EF 640 EN |
| STARTER MOTOR | WITHOUT STARTER MOTOR |
| CEN. LOCKING REM CONTROL FREQUENCY | 433.92 MHZ SUPER HETERODYNE |
| BATTERY CHARGER | THREE-PHASE 11 KW ON-BOARD CHARGER |
| MULTIPLEXING | R3 ECO ELECTRICAL ARCHITECTURE |
| ELECTRIC VEHICLE CHARGING PLUG | WITHOUT VEHICLE LOAD RECOGNITION |
| BATTERY CHARGE MEASUREMENT | BEV BATTERY CHARGE MEASUREMENT - BECB WITH DIAG 12V |
| LIGHTING OF LAMPS | AUTO LIGHTING + ADAPTIVE SWITCHING |
| Component manufacturers | |
| Miscellaneous | |
| SPECIAL SPECIFICATION | STANDARD |
| MODIF. DURING MODEL YEAR | "00" MINOR INDEX |
| CONDENSER (SPECIFICATIONS) | CONDENSER 24DM2 - THICKNESS 18 |
| ATMOSPHERIC CONDITIONS | NORMAL ATMOSPHERE |
| VIN PLATE | EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE |
| LABEL | WITHOUT LABEL |
| RADIO HEADPHONE SOCKET | SINGLE ACCESSORY SOCKET |
| TRAFFIC SIDE | DRIVING ON THE LEFT-HAND SIDE |
| SET OF KEYS | SET OF BADGE KEYS + BACK-UP KEY |
| DOOR SEAL | FRONT DOOR FRONT DIRT EXCLUDER SEAL+REAR DOOR LOWER |
| REFRIGERANT | AIRCON FLUID 1234 YF |
| EMERGENCY EQUIPMENT | PUNCTURE REPAIR KIT |
| SURFACE CONDITIONS | GOOD TERRAIN |
| SPEED MONITORING | WITHOUT SPEED CHECK |
| SLAVE CONTROL UNIT | BSI + COM 2008 + POLY SOUND + CHROME DECOR |
Crystalyne
- x 4
Many thanks!
Okay, seems like maybe the range number being different is a red herring then, as near as I can tell there isn't any (documented) changes to the DS3 prior to it's facelift in 2023.
Could I get the build sheet for this VIN as well please?
Thanks!
Thanks!
- x 6956
Here you go:
| AS/RP N° | 15768 81 1 0021 |
| Warranty Start Date | 29/12/2020 |
| Engine serial number | 10 5TAW 0001886 |
| OPB | 00KH |
| BER | e2*2007/46*0639*07 |
| Traction Battery N° | 760A0001017 |
| BODY COLOUR | KTV - BLACK PEARL PAINT |
| INTERIOR TRIM TYPE | NAPPA LEATHER "4H" |
| UPHOLSTERY COLOUR | "FJ" |
| ROOF (EXT. ASPECT) | BODY COLOUR ROOF |
| BADGE | E-TENSE |
| DRIVE BATTERY | TRACTION BATTERY 50KWH 18S 2P6S NMC622 CATL |
| TANK FILTER | CITHOUT RESERVOIR FILTER |
| Body Fittings | |
| SIDE MOULDINGS (DIMENSION) | WITHOUT SIDE PROTECTOR, WITH CHROME SILL |
| BUMPER | BODY COLOUR STANDARD FR/RR BUMPER+CHROMED GRILLE |
| HANDS FREE ACCESS AND STARTING | FRONT ACCESS+BOOT+SMART DEVICE+HANDS-FREE STARTING |
| ANTI-THEFT ALARM | VOLUME VARIATION+PERIMETER ANTI-THEFT ALARM-STD |
| CLIMATE (AMBIENT TEMP) | TEMPERATE COUNTRIES |
| DASHBOARD EQUIPMENT | PADDED LEATHER DECOR DASHBOARD |
| TRAFFIC INFORMATION READER | PREVENTION+CORRECTION+DETECTION OF EDGE |
| WIFI | WITH WIFI |
| STEERING WHEEL | FULL GRAIN LEATHER FULL 3-SPOKE STEERING WHEEL |
| Electrical | |
| BATTERY CHARGER | SINGLE-PHASE 7 KW ON-BOARD CHARGER |
| ELECTRIC VEHICLE CHARGING PLUG | T2 CABLE SOCKET G (UK) |
| BATTERY CHARGE MEASUREMENT | WITH BATTERY CHARGE MEASUREMENT |
| Component Manufacturers[/td] | |
| Miscellaneous | |
Crystalyne
- x 4
Hey,
Last one to get the build sheet for (hopefully)!
VIN as follows:
Thanks!
VIN as follows:
Thanks!
- x 6956
No Problem (now corrected - there were issues with Citroen's servers on that day
- it took a while for services to come back up after an issue - but seems fine now, so I've replaced the data with the correct info for you. This can happen when they do certain updates and combined with local caching can exhibit this behaviour.
| AS/RP N° | 16100 81 1 0073 |
| Warranty Start Date | 07/01/2021 |
| Engine serial number | 10 5TBQ 0004017 |
| OPB | 00KH |
| BER | e2*2007/46*0639*11 |
| Traction Battery N° | 810B0001037 |
| BODY COLOUR | EVL - PLATINUM GREY PAINT |
| BADGE | E-TENSE |
| Body Fittings | |
| WIFI | WITH WIFI |
| Electrical | |
| Miscellaneous | |
Crystalyne
- x 4
Weird!
The VIN should be for a DS3 Crossback - to double check, here's the VIN again, according to a VIN checker site this does match to the car.
- x 6956
All sorted - see the original post above - all corrected - server issues as I had a few other problems with them on that day.
