Expert Teepee 1.6hdi engine code/part number.
MrMRG
Unread post by MrMRG »
New to the forum. I have a 2010 Peugeot expert teepee 1.6hdi. Annoyingly the lower radiator hose burst off while driving and the engine overheated. I have not yet tried to see if it will turn over but I suspect the damage will be extensive and a new engine required. #-o
It has aircon and 90hp. Just wondering if anyone would be able to provide me with the engine code/part number of my engine fitted? Reg is SP60BJK. If the reg isn't enough I can get the VIN number later. I think its a DV6 9HU?
Also if I do get a new donor engine to replace it with, am I right in thinking I will just need to swap over the ECU and loom? The fuel pump/rail on the donor engine will work okay with my ECU? The new injectors will need to be coded which I can do with PP2000/diagbox?
Thanks, Matt.
x 6955
Re: Expert Teepee 1.6hdi engine code/part number.
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or specific vehicle information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
