So I have just purchased a used 2009 C5 Tourer Confort 2.0 HDi DPF which is in nice condition and drove very well. Service history, no leaks from rear suspension pipes or steering rack, no rust, suspension went up and down as expected etc. Good price (for France) too and only a couple of minor faults that hopefully someone can advise me on.
1. The orange LCD display is not working - just a vertical line down the middle. Can this be replaced with one from a breakers or is it programmed in?
2. Drivers door has lost its 'half open' stop - is this just a case of replacing a hinge?
3. The parking aid (front and rear sensors are installed) is not working at all - can it be fixed?
That's everything I picked up from the inspection/drive but there may be more as I drive it more (hope not!)
Thanks for any pointers
Finally got one :) - couple of minor issues to fix
steveclv
- x 40
moizeau
- x 429
Re: Finally got one :) - couple of minor issues to fix
Have you got Diagbox full chip version?
I swapped my dead screen in the 407 for one from a C4 from the breakers. It needed reprogramming to tell it would it could do / display.
The half closed door problem is the checker arm, you'll need to determine which bit is knackered probably by removing the door card.
Parking aid fault needs a diagnostic to give you a clue as to where the problem lies.
Pete
steveclv
- x 40
Not yet - I'm going to buy one but as I live in France I need to find the right one here (thanks Brexit!)
I've got a copy of ServiceBox + SEDRE from 2011 ready but just need the Diagbox
moizeau
- x 429
Where in France are you? It's a big place but there a few of us who live here or have 2nd homes.
Pete
steveclv
- x 40
Dept 86 - Poitiers
