C5 Aircross: Full-LED Headlights - Dipped Beam Fault "B1137 12"
JimmyTulip
Unread post by JimmyTulip »
Hello,
I have a C5 Aircross from 2019 with Shine-Pack and Full-LED headlights.
VIN: VR7**************[VIN obfuscated, can be read by forum staff]
In general ALL lights are working. When driving with High-Beam, visibility is great.
But I am annoyed by the poor visibility when driving with Dipped-Beam. On Dipped-Beam the lights point to low to ground and it is dangerous to drive, because you might see an obstacle too late.
At first I thought the headlights might be out of alignment and I was thinking to adjust them by the alignment screws.
But before I did anything I did connect the car up with DiagBox to read the fault-codes and unfortunately there was a fault related to the headlights:
B1137 12 - Fehler Ansteuerung des Abblendlichts vorne rechts (Kurzschluss an Plus)
I'm sorry, but the error on the sceenshot above is shown in german. The error should translate to something like:
B1137 12 - Right dipped beam control fault (Short circuit to positive)
I can clear the fault, but it comes back immediately, I think, after ignition off - ignition on or when switching on the headlights.
The handbook says, that in the event of a fault, the system places the headlamp beams in the lowest position:
And I think this is what is happening here and this may cause the poor visibility. Despite I DON'T get a warning on the instrument panel.
I can NOT remember, if the lights did a self-test on startup? I think they went up and down after ignition on, but I am not sure anymore.
However, at the moment they don't do something like that on startup.
I did have a close look on the headlight-connector, but I did NOT find anything suspicious:
I followed the cabling back behind the engine without taking anything apart and I was not able to find any visual damage or anything suspicious ...
I also took a photo of the part number of the headlight itself:
Normally I am a DIY-guy, but I do NOT have access to any information from Citroen. (service manual, wiring diagrams, ...)
I was not able to find anything helpful on the Internet.
Any tips? How should I proceed?
Thank you
x 6957
Re: C5 Aircross: Full-LED Headlights - Dipped Beam Fault "B1137 12"
There's probably not a lot you can do with this - apart from getting the dealer to check it out as the LED units are pretty much self-contained. There is a driver unit and the headlamp, so either could be faulty, or an issue with the BSI. The fault descriptor is below. If it's the headlamp internally, then it's a new lamp I'm afraid. But I would check the connector and the pins very carefully to ensure they are making contact and that there is no corrosion. Give the connector a spray with some electrical contact cleaner spray and try to see if this makes any difference.
Fault Code: B1137 12
Description of Fault: Front right dipped headlamp control fault: Short circuit to positive. Lamps not controlled.
Short-circuit to positive detected for 2s.
Conditions of activation of the diagnostics
The following conditions have to be met:
- Vehicle stationary
- Ignition on
- Not in economy mode
- Triggered
Conditions for Fault to clear:
  • Absence of malfunctioning and activation of the control (For 2 seconds)
Downgrade Modes whilst Fault is active: -
Symptoms:
  • Malfunctioning of the dipped beams
  • Malfunction of the cornering or junction lighting
  • Malfunction of the front foglamps
  • Automatic lighting failure
Suspect Areas:
  • Built-in systems interface
  • Headlamp
JimmyTulip
Hello @GiveMeABreak,
Thank you very much for the fault descriptor!
Yes, I have cleaned the connector using contact cleaner, but it did not make any difference.
When I read about "Short circuit to positive" I was all-in on the wiring-side.
The fault descriptor also does not contain anything about the wiring?
May I rather exclude a fault from the wiring-side?
Do you perhaps know for sure, if the lights normally do a self-test on startup? (move up and down)
Thank you
x 6957
No, not on these, that used to be a feature of the Xenon directional lighting, not the LEDs which are static I believe. I think only some later top models have active matrix LED lighting.
JimmyTulip
Assuming I would get a new headlight with the same part number as mine "9816925280" (new or second hand):
I know the headlight(s) would have to get adjusted using a car headlight tester, but ...
Would the new headlight has to be coded somehow into the system or will it work out of the box? (Plug and Play)
Thank you
x 6957
Not as far as I'm aware.
