My clutch master cylinder has basically seized
I cannot get the same cylinder anywhere including Citroen dealers
The low and high pressure connections are at right angles to the cylinder so pipes run against the bulkhead
Part number is 2182 A6
9681439680 ( this number not known by dealers)
Does anybody know of a compatible replacement part or do I have to change all the hydraulic pipework to match a different master cylinder
Matt
C5 clutch master cylinder
- x 6945
Re: C5 clutch master cylinder
We can help if you need an original genuine part number, part diagram or factory build sheet and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
But I can tell you 2182 A6 is not listed for a 207.
| A response to your question by a Forum Admin requiring parts or specific vehicle information requires you to have made a current contribution (Min. £10 / €11.48 or equivalent) to the Forum. |
Mwalking
Information was supplied by the dealer
Funnily enough they were WRONG . car is fitted with the older unit
P/N 2182 74
This is not available through the dealers or as an aftermarket part ( that I can find )
Got a part from a scrapyard
P/N 2182 74
