Hey guys, is it possible for front suspension strut to start leaking after car being lifted for service?
Some oil appered on left side. I did not yet had time to check. I am not sure if it is uspension as car keeps height (i would expect to drop down).
Will clean everything first to better see but any sugestions where and what to check are welcomed.
Br Alex
Citroen C5 x7 leaking after being lifted
furriegurrie
- x 40
Re: Citroen C5 x7 leaking after being lifted
If the car hasn’t been put on the highest setting before lifting it with 4 wheels from the ground it is definitily possible something has sprung a leak.
Most common issue is the LDS tank splitting or overflowing
- x 6955
See this post:
LDS Tank Bursting Warning Labels
It may be that you have a leak form the strut. But you first need to identify where it is coming from. The car won't crash down for small leaks until the reservoir fluid runs low.
If there is a small pool forming under the steering rack pinion seal, it will be bad news as that will likely mean a new rack and the pipes are now hard to come by. If it's the suspension strut, then it means a new strut, as these are non-repairable, with the rubber bonded to the metal unlike previous models that had replaceable seals leak-back pipes on the struts. The X7 doesn't have the same system.
alex666
Car has been put to highest settings. Only front was lifted of the ground. Leak is on other side of the tank.furriegurrie wrote: 31 Mar 2024, 13:29 If the car hasn’t been put on the highest setting before lifting it with 4 wheels from the ground it is definitily possible something has sprung a leak.
Alex
alex666
Will clean evrything in next days and then dig into.thanks for directions.GiveMeABreak wrote: 31 Mar 2024, 16:23 See this post:
Alex
