fault codes
murdy67
fault codes
hi new on the site so please bear with me. i bought the daughter a 2017 c3 mk 11 its had a few problems the latest one was emissions the local garage put on new cat and front and rear lambda sensors. the e.m.l. went off but came back on with a fault code p0054 .this is a different code than the one for emission. can anybody tell me what this code means. thanks.
- x 6946
Re: fault codes
Hi and welcome.
P0054 can indicate that the downstream oxygen sensor electrical harness or the sensor is faulty, but I may be able to be more specific if you pop the VIN up.
Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
