Hi im new to the forum I'm having bother with my c3,intermittent high fuel pressure,bringing on the warning message anti pollution fault.
My chassis number is VF7**************[VIN obfuscated, can be read by forum staff] and engine number JBBK3015936.
Can you advise please if I have a dpf and eolys system fitted to my car.
Many thanks.
Does My c3 picasso 1.6 hdi have a dpf or Eolys system
Tony7062
- x 6948
Re: Does My c3 picasso 1.6 hdi have a dpf or Eolys system
Hi and welcome.
No, this vehicle has no particle filter fitted.
PaulC5
- x 705
You need to use a code reader to see what fault the car thinks it has. Trying to guess and replace parts hoping to get the right one that might be faulty can be expensive and still not fix a fault. When you have the fault code post it on here for some help.
Tony7062
Thank you,it has an intermittent too high fuel pressure fault,I've not got the code here but will find out tomorrow.
Much appreciated.
Much appreciated.
Tony7062
Hi,further to my post I have found out the code is P1166 intermittent fault and P1351 permanent fault,does anyone have any experience of these? Thanks.
- x 8151
Hi Tony, I have no direct experience of either code but it seems many others have had. If you click on the 'citroen' forum at the top of this page and then put in one of the codes in the search box it will give you a list of all the previous issues with that code. Then do it for the second one. I believe the P1351 is usually to do with poor earthing and relates to the glow plugs and glow plug relay. The other code appears to be a known fault so have a look and I suspect you'll find an answer!! Good luck
Tony7062
Many thanks...
- x 6948
| Fault Code: | P1166 |
| Description of Fault: | High pressure fuel regulation: Measured rail pressure higher than the maximum pressure. Pressure of the fuel high pressure common injection rail measured higher than the maximum pressure (for 5 seconds). |
| Conditions for Fault to clear: |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
