Does My c3 picasso 1.6 hdi have a dpf or Eolys system
Tony7062
Unread post by Tony7062 »
Hi im new to the forum I'm having bother with my c3,intermittent high fuel pressure,bringing on the warning message anti pollution fault.
My chassis number is VF7**************[VIN obfuscated, can be read by forum staff] and engine number JBBK3015936.
Can you advise please if I have a dpf and eolys system fitted to my car.
Many thanks.
x 6955
Re: Does My c3 picasso 1.6 hdi have a dpf or Eolys system
Hi and welcome.
No, this vehicle has no particle filter fitted.
PaulC5
x 665
Unread post by PaulC5 »
You need to use a code reader to see what fault the car thinks it has. Trying to guess and replace parts hoping to get the right one that might be faulty can be expensive and still not fix a fault. When you have the fault code post it on here for some help.
Tony7062
Thank you,it has an intermittent too high fuel pressure fault,I've not got the code here but will find out tomorrow.
Much appreciated.
Tony7062
Hi,further to my post I have found out the code is P1166 intermittent fault and P1351 permanent fault,does anyone have any experience of these? Thanks.
x 8065
Hi Tony, I have no direct experience of either code but it seems many others have had. If you click on the 'citroen' forum at the top of this page and then put in one of the codes in the search box it will give you a list of all the previous issues with that code. Then do it for the second one. I believe the P1351 is usually to do with poor earthing and relates to the glow plugs and glow plug relay. The other code appears to be a known fault so have a look and I suspect you'll find an answer!! Good luck :)
Tony7062
Many thanks...
x 6955
Fault Code: P1166
Description of Fault: High pressure fuel regulation: Measured rail pressure higher than the maximum pressure. Pressure of the fuel high pressure common injection rail measured higher than the maximum pressure (for 5 seconds).
Conditions for Fault to clear:
  • Driving for 5 minutes
Downgrade Modes whilst Fault is active:
  • Engine stopped
  • Irreversible cutting of the cruise control
  • Deactivation of automatic mode for the electronic parking brake
  • Deactivation of the speed limiter
  • Switching on of the warning lamp and/or warning message: Warning lamp MIL
Symptoms:
  • Lack of power
  • Jerking/stalling
Suspect Areas:
  • Electrical harness
  • Connectors
  • High pressure fuel pump
  • Fuel flow regulator
  • Low pressure fuel circuit
  • Fuel filter
  • Engine ECU
  • High pressure fuel sensor
P1351 is basically the pre-heating relay circuit: Coherence; Relay supplied and glow plugs not supplied. The information from the preheating control unit indicates that the relay is open even though the ECU commands the closing of the relay for 2 seconds. This may be the Pre-heater plug, Electrical harness or Pre/post heating relay.
