Please note that I have updated the article on Stellantis Engine Oils as of February 2024.
It is important to note that due to issues with the EB2 Engines, and DV5 engines as 2 examples, specifications of oil and grade have been changed. These 2 examples concern the 'Belt in Oil' system of the EB2 engines and the Camshaft Chain on DV5 engines, where the oil has been changed to afford better protection respectively.
Although dealers will be aware of the these changes, independent garages may not, so I encourage you to double check the specifications for your vehicles to ensure you minimise issues.
Furthermore, there have been changes to the countries list and removal of some oil grades.
Revised Article here:
Article Updated to Reflect Changes to Specifications and Oils from February 2024
Stellantis Engine Oil Update
- x 6954
