Peugeot 3008 experiencing multiple fault codes following tire replacement
cekudd
Unread post by cekudd »
I am reaching out to you as I am facing significant issues with my car.
This past Saturday, I experienced a flat tire on the front left side and had to tow my car. Subsequently, I acquired some good used tires that were fitted to the front axle on tuesday. It's worth noting that the original tires were 225/65/R17, while the ones we fitted were 225/55/R17. Initially, everything seemed fine. Noteworthy a heavy snowstorm was over the town at the time.
However, yesterday (wednesday), while driving to work, various fault codes started appearing (ABS system, ESP system, parking brake, power steering, etc.), and the car's power decreased noticeably.
Fortunately, I managed to reach work and attempted to clear all fault codes. I succeeded in clearing all but U0415. I took a chance and drove home in the afternoon. After some time, the fault codes reappeared, and the car seemed to stutter while driving, as if the ABS was reacting. I stopped the car and sought help from my brother, who assisted in getting the car to a garage. We connected an OBD reader (see below). Does anyone have an idea of what the fault might be? :(
I have a few thoughts that I would like to share with you:
Could snow have affected some sensors?
Could the different tire dimensions be causing the issue?
Could the ABS sensor have been damaged when I had the flat tire?
The car is currently in a warm garage to test the first idea, and this afternoon, I plan to check the ABS sensor. If you have any additional insights, I would greatly appreciate hearing them.
Thank you in advance!
DTC report
Connection profile: Peugeot OBD-II / EOBDDate: 2024-02-07 07:04:40
OBD-IIOBD-II
DTCs: 1
U0415 [0xC415]
Invalid data received - anti-lock brake system (ABS) control module
Status: Confirmed
Engine control unit#1
No DTC found.
Transmission control unit#1
No DTC found.
Engine control unit#3Engine control unit#3
DTCs: 3
U3FFF(FF) [0xFFFFFF] Archive (inactive)
Status: Test failed since last DTC clear
U1213(81) [0xD21381]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
U0415(81) [0xC41581]
Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
Transmission control unit#3 / BSI
No DTC found.
Engine control unit#4Engine control unit#4
DTCs: 3
Power steeringPower steering
DTCs: 1
U1213 [0xD213]
Status: Test is inhibited by other DTC, Validated and stored in non volatile memory
ABSABS
DTCs: 1
C1387(00) [0x538700]
x 1485
Re: Peugeot 3008 experiencing multiple fault codes following tire replacement
Welcome along. I imagine this is the cause:
cekudd wrote: 08 Feb 2024, 07:06
ABSABS
DTCs: 1
Seems to be problem with Right rear sensor. If it's like the C4 Picassos, the the wiring may have rubbed through on the ducting to the sensor, rather than an actual sensor fault.
cekudd
Hello RichardW, thank you for your response!
So, you don't believe the issue is related to the different tire dimensions or that snow could be a contributing factor? If I understand correctly, I should be able to identify the potential problem by tracing the wires from the right sensors, is that accurate?
RichardW wrote: 08 Feb 2024, 08:20 Welcome along. I imagine this is the cause:
ABSABS
DTCs: 1
