Citroen relay fuses
daviemck2006
x 485
Citroen relay fuses
Unread post by daviemck2006 »
Hi. My relay wouldn't start last week, when the starter engaged there was a click and it went dead, no ignition lights. I called the AA. Thought about a bottle of whisky, but that's the other AA lol. The patrol van dul arrived, did a bit of fault finding including looking at the battery under the passenger footwell. Under there is a fuse box I never knew about. There is a mega fuse, which was blown. This is as the name suggests a big fuse of 150w. The AA man replaced this, he had a 150wone in his van, and service resumed on my van. He did say that this rating of fuse did not seem big enough. Fast forward to today, turned key, click,no ignition lights. First question, does anyone know what rating this fuse should be before I go get one? Second question, why would this fuse blow twice in a few days on a van that has had no gremlins with starting over the last 10 months? The van was cold and had not been ran for about a week the first time, it was warmed up and been ran and started a few times today. Thanks in advance, Davie
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 1060
Re: Citroen relay fuses
Unread post by wheeler »
First thing that springs to mind would be the starter starting to seize if its blowing it just as you start cranking. I have known these mega fuses to pop after accidentally trying to start the van in gear.
Not sure of the rating off hand & cant look it up just now. Is it the orange one thats marked CAL 4?
daviemck2006
x 485
wheeler wrote: 30 Jan 2024, 20:09 First thing that springs to mind would be the starter starting to seize if its blowing it just as you start cranking. I have known these mega fuses to pop after accidentally trying to start the van in gear.
It was an orange one which failed and the aa man put in an orange one. I do not know what was written on it. I can't look at the moment, the van is abandoned at a friend's house, I will go look at it in the next couple of days. I have a hospital appointment tomorrow which is more important than an old camper.
Peugeot boxer 2016
In the family
Craig1984
Unread post by Craig1984 »
Hi I've just had this problem on my relay and can't find the big fuse,can you explain where is is please?
Many thanks
x 1060
Its on a little fuse box attached to the battery positive terminal, looks like this.
Craig1984
How can you tell which 1 blew?sorry for the daft question
x 1060
Easiest way is to use a test lamp or volt meter on either side of it, If one side lights up/shows voltage & the other side doesent then the fuse is blown.
