Bearing Cap Bolts
darbuck
- x 289
Bearing Cap Bolts
Hi Marc, can you give me the torque specs for the crank and Conrod bearing cap bolts for my C5 please.
Reason: Moved out of Parts Requests into Separate Thread
Darren
- x 6945
Re: Bearing Cap Bolts
Reciprocating Gear - Tightening Torques
Order of tightening of the crankshaft bearing cap fixing bolts
(4): Crankshaft bearing caps fixing bolt.
| Reference | Designation | Tightening Procedure |
| (1) | Ancillary drive pulley fixing bolt | Pre-tightening to 7 ± 0,7 daN.m |
| (1) | Ancillary drive pulley fixing bolt | Angular tighten to 62 ± 3 ° |
| (2) | Underside of piston jet (Overhaul) | Tightening to 1 ± 0,1 daN.m |
| (3) | Big end nuts | Pre-tightening to 2 ± 0,2 daN.m |
| (3) | Big end nuts | Angular tighten to 70 ± 5 ° |
| (4) | Crankshaft bearing caps fixing bolt (*) | Pre-tightening to 2,5 ± 0,2 daN.m |
| (4) | Crankshaft bearing caps fixing bolt (*) | Angular tighten to 60 ± 5 ° |
| (5) | Crankshaft sealing flange | Tightening to 1,4 ± 0,1 daN.m |
darbuck
- x 289
darbuck
- x 289
Hi All,
before I put this back together, Can anyone tell me if they think the bearings need replacing there is some very light scoring/scratches and discoloration? I also would like some advice on on the finish on the lobe of the crank. It's the really rough looking surface in the 4th and 5th pics it looks deliberate to me I imagine it is factory and is to aid distribution of oil in the Sump.
Darren
moizeau
- x 423
Plastigage and factory specs would be you friend here. Can you feel any roughness with a fingernail?
Pete
darbuck
- x 289
darbuck
- x 289
Had an engine builder have a look at these he said they are fine so a win I think.
Darren
