Today my car developed a fault with its electric hand brake and wouldn't operate. Got the car home locked itt and left it sitting for a couple of hours then i jumped in and pulled the handbrake button and the handbrake engaged..i could clearly hear the motor go and the rear brakes lock up...i managed to drive off no problem but then within seconds the fault came back.... does anyone have any ideas what could be wrong
Cheers
2015 c4 grand picasso handbrake fault
- x 1496
Re: 2015 c4 grand picasso handbrake fault
Welcome
Quite likely that some of the wires to the handbrake motor(s) have rubbed through on the inside of the trunking. Peel back the cover and look for any spots of corrosion.
Psmk222
Hi... thanks for the reply..is the trunking the thick black plastic tube behind the caliper..i can see it behind the wheel.... do i just split that and pull the wires out
- x 1496
Yes, that's it. It might be something else, but this is a common issue on these, and easily checked.
Psmk222
Thanks a lot... judging by the luck I've had this year i suspect it will be an absolute nightmare
- x 8423
Psmk222
Still cant get looking at it till this wind and rain stops and we have another storm due tonight but oddly enough the handbrake had started working intermittently.. hopefully this drys up soon so i can get a proper look....i just purchased new rear pads and discs as the ones on it are completely worn down ... not sure if worn pads and discs could be contributing too the problem or not
- x 1496
Psmk222
Im in fife..i do have a garage but when i reversed the Citroen in i didn't have any room to get the wheels off
Psmk222
Fixed it today... thanks Richard i found a broken red wire right where you said.. thanks a lot... changed the rear discs and pads as well as the front pads.. cars all tip top now
- x 8423
