How do you remove the front bumper on a 2014 Citroen C3 Picasso, I need to check/replace the car horn.
Registration NX64 LLG?
Is there 10 bolts/screws ?
Any wiring to disconnect?
Easy to do & refit?
Citroen C3 Picasso 2014
Coff9
Reason: Moved to Citroen Forum
- x 8422
Re: Citroen C3 Picasso 2014
I'm keen to see the answer to this too
It might be good to confirm yours has the 'facelift' front end with DRLs just in case there's a difference in procedure between early and late models.
Coff9
What is DRL's?
Yes it has face-lift front end and top securing pins are plastic with two pins underneath, not sure about wheel arches though ?
- x 8142
I think that's Daylight Running Lights
- x 8422
Coff9
Yes it has daylight running lights
- x 6946
There shouldn't be any need to remove the bumper. You should be able to get access to is via the near side wheel arch after you have removed the wheel arch trim.
Horn is (5)
Horn is (5)
