ABS, Hill Start, ESP/ASR, Tyre Pressure Sensor faults
Losttotheworld
Unread post by Losttotheworld »
Hi all I’m hoping for some help and advice
My car a C4 Grand Picasso 15Reg, currently has ABS, Hill Start, ESP/ASR and Tyre Pressure faults. The right rear wheel speed sensor has just been replaced following diagnostics, however this has not cleared the above faults, I’m also having issues with the electronic window drivers side unit, only operating the drivers window.
I’m looking for advise to understand if this would be a possible wiring harness fault or BSI issue, I have already looked at the wiring from the wheel speed sensor up to the chassis but I can not get the car up in the air to further investigate wiring seems to be okay up to that point.
Any help advice would be greatly appreciated.
x 6946
Re: ABS, Hill Start, ESP/ASR, Tyre Pressure Sensor faults
Were the same faults present before the sensor was replaced and after? If so have a read of my post here and the following few posts after:
viewtopic.php?p=660516#p660516
Losttotheworld
Thanks for your response
Yes, same faults are still present, wheel sensor showing 655mps stationary with engine off
Dustysweeper
x 20
Unread post by Dustysweeper »
I had this same problem. Turned out to be a rotten wire and a bad magnetic ring on the bearing.
This thread may help
viewtopic.php?t=73516&start=15
