Citroen Jumpy II central monochrome display diagram
Falka
(Donor 2022)
x 5
Unread post by Falka »
Hello.
The subject is a Citroen Jumpy 2007-2016.
Because it's a van, it was possible do order it without any factory radio, but with the regular small monochrome display. In this scenario, there are 3 buttons beside the lcd to control it. Picture attached.
I would like to retrofit this, but I can't seem to find any oem number for the parts or diagram about its wiring...
If you could be any help with this... 🙇???
UPDATE: I found the wiring diagram for it. Now Im only looking for the lcd frame oem number
x 6946
Re: Citroen Jumpy II central monochrome display diagram
The diagrams are vehicle and equipment / option specific, so may not be any use from the VIN if it was never fitted.
If you want the part numbers for the display, happy to provide those, but your parts sub has expired Falko :wink:
Falka
(Donor 2022)
x 5
Ah very true. I will search a bit more then report back 👍
