Early C8 wiper blades
tearing hair out
x 19
Unread post by tearing hair out »
Happy New Year too all.
Buying wiper blades for my '54 C8, I've just realised that they are really niche - they fit the first few years of 2nd-gen Eurovans and nothing else. I'm wondering how long before Bosch stop making them...
Before I panic-buy 10 pairs, does anyone know how feasible it would be to fit later-model wiper arms to my C8? I bit of a long-shot, but maybe someone's made the conversion - or has an early and late C8 and can compare?
I suspect the issue is that mine have built-in spray jets on the blades - maybe later C8s have something different?
Paul
I would have more Citroens if I had the space...
tearing hair out
x 19
Re: Early C8 wiper blades
I suspect, worst case, I get some of these: https://www.ebay.co.uk/itm/175272182278
Paul
x 1060
Unread post by Rp0thejester »
Spray jets on the blades? Not heard of that, please give us more details my fellow C8 friend. I've personally never heard of wiper blades that shoot screen wash through them. As for wiper blade size not being in stock I very much doubt it, they can't design a car without using 100 parts from another car, everything is mass produced.
x 5657
Throwback to the BX.
x 1060
How did the BX wipers do? Reliable?
x 5657
Seemed OK to me.
x 3300
My Vauxhall Combo has a similar screen wash setup to the BX.
x 5657
Never noticed that on mine James, perhaps an earlier model.
x 8310
myglaren wrote: 12 Jan 2024, 21:39 Throwback to the BX.
Absolutely, and on some Xantia rears too...
x 3300
My company Combo is the current model, when Vauxhall joined the Stellantis garage.
tearing hair out
x 19
Rp0thejester wrote: 12 Jan 2024, 21:27 Spray jets on the blades? Not heard of that, please give us more details my fellow C8 friend.
There are little plastic nozzles clipped onto the blades - I think I actually moved them from the old blade to the new ones last time, but I don't want to rely on that in case they break or the blade design changes and they stop fitting.
It's reassuring that other cars use this, since that means they will probably keep making the plastic part. I suspect it's just that the early C8s (and related) are they only ones with this on a pair of 26" blades.
Paul
x 3300
The Combo washer system is not on the blades themselves, but running up the wiper arms (which is how I remember it for my 1990 BX).
tearing hair out
x 19
Ah, so perhaps it is something semi-unique to the early 2nd gen Eurobuses. My CX also had a pipe mounted on the arm - which worked really well.
Paul
x 1060
It just sounds a really bad idea for it come out of the wipers. On Transit vans they are fitted on the bonnet and freeze up often, my C8 has the jets behind the bonnet in the grille and they still freeze shut. I'd imagine that would be the case on wiper jets in cold weather and at motorway speeds
tearing hair out
x 19
Strangely, I've never really noticed them freezing. That used to happen all the time on my XM, but perhaps the fact that the jets shoot water downwards (blade to screen) rather than upwards (bonnet to screen) helps with that. I suspect it isn't the screenwash that freezes - it's rainwater sitting on the jet.
Paul
