Hello,
I have a problem with Citroen Jumper III, engine: 2.2 HDI 150 PUMA C
The program reads the following errors:
P0423-92
and
P2002-7A
The DPF was washed, but it didn't change anything.
Where to look for the cause?
Will replacing the fuel injector help? Does it need to be specially programmed?
Citroen Jumper/Relay III - DPF error
seba65310
- x 6950
Re: Citroen Jumper/Relay III - DPF error
When you had the DPF cleaned, you must tell the engine ECU the DPF has been replaced - otherwise it will not know which concerns the second code, but also the first code concerns the atomiser of the fuel at the exhaust:
| Fault Code: | P0423 92 |
| Description of Fault: | Atomizer for injection of fuel at the exhaust: Internal fault. The time of appearance of the fault code is 1 seconds Conditions of activation of the diagnostics The following conditions have to be met: - Ignition on - Particulate filter regeneration - Coolant temperature above 50°C |
| Conditions for Fault to clear: | - |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P2002 7A |
| Description of Fault: | Particle filter: Detected absent. Particle Emission Filter absent, The time of appearance of the fault code is 12,7s Conditions of activation of the diagnostics: All except regeneration of the particle filter. |
| Symptoms: |
| Suspect Areas: |
seba65310
How to inform the DPF about its replacement?
- x 6950
Via the diagnostic tool (Diagbox) or similar professional-level diagnostic tool replacement parts section or similar.
