Citroen Jumper/Relay III - DPF error
seba65310
Unread post by seba65310 »
Hello,
I have a problem with Citroen Jumper III, engine: 2.2 HDI 150 PUMA C
The program reads the following errors:
P0423-92
and
P2002-7A
The DPF was washed, but it didn't change anything.
Where to look for the cause?
Will replacing the fuel injector help? Does it need to be specially programmed?
x 6950
Re: Citroen Jumper/Relay III - DPF error
When you had the DPF cleaned, you must tell the engine ECU the DPF has been replaced - otherwise it will not know which concerns the second code, but also the first code concerns the atomiser of the fuel at the exhaust:
Fault Code: P0423 92
Description of Fault: Atomizer for injection of fuel at the exhaust: Internal fault. The time of appearance of the fault code is 1 seconds
Conditions of activation of the diagnostics
The following conditions have to be met:
- Ignition on
- Particulate filter regeneration
- Coolant temperature above 50°C
Conditions for Fault to clear: -
Downgrade Modes whilst Fault is active: -
Symptoms:
  • No effects immediately perceptible to the customer
  • Smoke from the exhaust
  • Fluid leak/smells (diesel fuel, oil, etc.)
  • Absence of automatic stopping of the internal combustion engine
Suspect Areas:
  • Electrical harness
  • Connectors
  • PEF upstream temperature sensor
  • Vaporiser
  • Catalytic converter upstream temperature sensor
  • Particle filter
  • Metering pump fuel supply circuit
  • Metering pump for injection of fuel into the exhaust
Fault Code: P2002 7A
Description of Fault: Particle filter: Detected absent. Particle Emission Filter absent,
The time of appearance of the fault code is 12,7s
Conditions of activation of the diagnostics: All except regeneration of the particle filter.
  • Driving for 5 minutes with several full load accelerations for 10 seconds
  • Warning lamp MIL
Symptoms:
Suspect Areas:
  • Electrical harnesses
  • Connectors
  • Particle filter differential pressure sensor
  • Particle filter upstream temperature sensor
  • Air flow meter
  • Particle filter
  • Tappings for the differential pressure sensor of the particle emission filter
seba65310
How to inform the DPF about its replacement?
x 6950
Via the diagnostic tool (Diagbox) or similar professional-level diagnostic tool replacement parts section or similar.
