Hello,
We got an oldie but really nice Peugeot 206 1.4i 55kW, 2005 with AL4 automatic transmission for my wife as a first car.
I am currently doing oil change on the transmission, but I am a little hesitant about installing the leveling plug back. The leveling plug does not have "a lip" and I can't see inside the hole because the oil is dripping from there.
I am worried that if I tighten the plug too much it will fall into the transmission. Or is there any "lip" inside that prevents the leveling plug falling into the transmission?
Can AL4 leveling plug fall in the transmission?
Arkis
- x 27
Citroen C4 Picasso 2013, 1.6 e-HDI 85kW, 6 speed manual
Peugeot 206, 2005, 1.4i 8v, 55kW, 4 speed AT
Peugeot 208, 2019, 1.2i PureTech, 61kW, 5 speed manual
Opel Insignia, 2015, 2.0 CDTi, 120 kW, 6 speed AT
Hyundai Santa FE 4WD, 2015, 2.2 CRDi 145 kW, 6 speed AT
- x 1055
Re: Can AL4 leveling plug fall in the transmission?
Dont worry, it would be a really bad design if the level plug was allowed to go right inside.
Here is an internal cutaway pic that shows it butting up against the inside of the box.
Arkis
- x 27
Thank you very much! I was a bit worried because it kept going for longer than I remember unscrewing it.
It really bottomed out only a few turns from my point.
