2014 C5X7 Sedan Windscreen washers front not working.
ozzdownunder
Unread post by ozzdownunder »
The front windscreen washer outlets are not working. The head light washers are ok and working fine. Checked the front outlets seems not blocked. What else could this be ? Any diagrams to show the pump and pathway of the tubes?
x 6950
Re: 2014 C5X7 Sedan Windscreen washers front not working.
These have separate pumps for the windscreen washers and for the headlamp washers, so likely the windscreen pump has failed and needs replacing.
We can help if you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum. For this service, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then provide your vehicle's VIN in full, which will be masked automatically when you submit your post.
A response to your question by a Forum Admin requiring parts or additional information requires you
to have made a current contribution
(Min. £10 / €11.48 or equivalent) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
ozzdownunder
Thank u. I have located the diagram and original part number.
ozzdownunder
Thanking all for your replies. Managed to obtain a SH motor and replaced it. Meantime fixed the original motor as it was clogged up.
