Citroen C3 Picasso Blower Motor Not Working
Balister
Unread post by Balister »
Hi,Blower Motor inside car went off.
Turned out wiring at side of heater box melted.
Try this first before you take glove box out etc to get to motor.
If you take passenger side heater box plastic cover off,2 trim clips holding it on,you will see a block connector with red&brown wire just above carpet.
Flick clip out& turn plug round to face you & undo.It will be burnt inside.
Either clean up or hard wire(cut plug&solder together)for good connection.
Just wanted to put this on here as forum has helped me a lot.Thanks :-D
x 8234
Re: Citroen C3 Picasso Blower Motor Not Working
Excellent :) Thank you!
Roenjeroen
Unread post by Roenjeroen »
Thank you, your solution saved me many hours of work and was exactly for the same problem.
Stewart(oily)
x 35
Unread post by Stewart(oily) »
Worth knowing, thank you.
davrob89
Unread post by davrob89 »
Could anyone tell me how the plug and socket come apart please? Does the blue bit it the middle come off? Thanks
Bahaahssn
New User
Unread post by Bahaahssn »
Hello can someone tell me the access location of the blower motor at the left side ( the driver side for all the world or the right side the driver side fo uk only
