My 308 failed to proceed today.
The fault codes are:
P1385
P2337
P061F
P0565
P3010
P3010 will not erase.
Marc, can you look up the official notes on these?
I suspect that I need to pull the throttle body, but that is not a nice thing to be doing.
THP Engine Fault Codes
- x 1468
- x 1468
Re: THP Engine Fault Codes
I found some bad news here: viewtopic.php?t=75642
- x 1468
The thick plottens...
- x 1468
I removed that wire tie and the P3010 fault disappeared, but there were still permanent faults with throttle calibration and the throttle actuator test would not work.
I reassembled far enough to start the engine, but it was not very happy, with erratic idle.
I reinitialised the ECU auto-adaptives and went through the throttle calibration procedure.
It now seems to be idling OK, and all of the fault codes have cleared. I will take it for a test run tomorrow.
- x 6945
I've only just picked this up (time difference) so assume you don't need these codes descriptors now Mike? Not sure what the heck that 'dip stick' type thing you found was - can only assume it was some diy tool that has been pulled / sucked in from somewhere in the past!xantia_v6 wrote: 29 Nov 2023, 05:07 My 308 failed to proceed today.
P1385
P2337
P061F
P0565
P3010
