Peugeot 508 MCP oil change
trollkarlen
x 4
Unread post by trollkarlen »
I know that the oils in this gearboxes should last a lifetime.
But I think my car i almost on its second life time 😁
It has traveled 380000km now and lately i sounds like the gears mostly from neutral to first gear clonks a little louder. And the oil and job is not such a stretch either.
Is this a waste of time or should i do it ?
I guessed that the oil is Total gear 8 75W80 is that right ?
x 1240
Re: Peugeot 508 MCP oil change
Unread post by Peter.N. »
From my own experience I would say change it. I had a CX25DTR turbo many years ago I checked the oil several times in the first couple of years and it was always clean and full so I ignored it for the next 100,000 miles or so, I eventually had the synchro on 5th gear fail, when I came to look it the oil was black but it was all still there.
The car had done well over 200k miles by this time, I managed to repair fifth without removing the gearbox as it was located in the extension, but it taught me a valuable lesson.
trollkarlen
x 4
Thanx peter, then ill change the oil.
Will measure the output to se how much was in it also 😁
Anyone else with a 508 1.6 hdi MCP gearbox that have gone this far?
And what usually breaks on these cars ?
trollkarlen
x 4
Lucky i changed the oil because out came only 0.6 liters of the around 2 liters thats supposed to be in the MCP gearbox 😱
trollkarlen
x 4
Is it possible to check the level without dumping the oil ?
trollkarlen
x 4
Is the oil level supposed to be above the drive shafts?
I want to know if I can remove the drive shafts without changing oil?
x 6955
You are going to lose some oil for this operation, so you'll either have to measure and replace the exact amount that comes out (difficult to do) or just drain the manual gearbox, do the job and then replace the gearbox oil with some nice fresh stuff.
If you need help with the correct amounts, pop your VIN up so I can get the correct info as these differ considerable depending on the type of gearbox. Please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff.
trollkarlen
x 4
Thanx alot!
//R
x 6955
Quantity of oil to fill after draining : 2,1 ± 0,1 litres.
Quantity of oil to fill after an overhaul : 2,2 ± 0,1 litres.
Oil quality: 75W80
trollkarlen
x 4
Thx 💜
trollkarlen
x 4
Adding some info for other people.
This is the MCP 6 speed piloted manual gearbox.
Drain plug torq: 40nm
Drainplug needs a 8mm square socket, i created my own from a m10 hex screw with an angel grinder. And you fill from the air vent ontop of the gearbox under the air intake tube.
//R
