I'm trying to extract fault codes from the ECU, and I build my own Fault code reader, using this diagram: http://cit-faq.de/faqforum/beitraege/codes/codes.htm
But I can't seem to find this green 2-pin connector anywhere.
After browsing this forum, I read in a thread, that apparently it's possible to do the same thing, using the Engine Management Light in the dashboard, by shortening 2 pins on the diagnostics-connector found by the fuse-box by the steering wheel.
Can anyone tell me what pins to shorten, and other usefull information about this?
Thanks in advance,
Frank Hansen.
Diagnose Xantia using Paperclip-method
Firstly unless yours is one of the very first Xantias then it will not have a 2 pin connector.
Up until roughly the introduction of the MK2 Xantia they had a 30 pin connector in with the fuses where the handbooks are kept, Mk2s then went onto a 16 pin connector. If either of these connectors are fitted then the paperclip method won't work, you need a professional code reader.
Oh, ok.
Well, mine is a '95 Xantia 1.6i with the Magneti Marelli 8P ECU.
Is has the 30-pin connector, so I guess I'll have to visit my Citroën-dealer then
It's just that they want ~£120 to extract the fault codes for me ... I think its kind of expensive, for say max. 15 mins of work
Thanks for you reply
Frank Hansen.
Frank Hansen.
This any good?? I know nowt about them but happened to spot this while browsing
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 52407&rd=1
pwatson:
I also looked at this item, but by studying the manual (found here: http://www.drapertools.com/draper/external/68079ins.pdf) you'll see that this also mentions the green 2-pin connector found in the engine compartment.
So I don't think it'll work...
Frank Hansen.
Frank Hansen.
Thank you for the offer Richard. Unfortunatly I live in Denmark, so I think it'll be cheaper to just take it to the repair shop
By the way, I just received this link on mail: http://xantia.rtkmail.ru/files/diags.pdf
saying it should be possible to ground the C3-pin from the 30-pin connector .. Well, I don't know. I remember measuring the voltage on this pin, gave ~13.8V (with engine running) - I'd think it would be 0V, since the Engine Management Light is not on...
Anyways, perhaps I'll give it a try tomorrow, or just take it straight to the shop...
