Diagnose Xantia using Paperclip-method
spinner
Unread post by spinner »
Hi,
I'm trying to extract fault codes from the ECU, and I build my own Fault code reader, using this diagram: http://cit-faq.de/faqforum/beitraege/codes/codes.htm
But I can't seem to find this green 2-pin connector anywhere.
After browsing this forum, I read in a thread, that apparently it's possible to do the same thing, using the Engine Management Light in the dashboard, by shortening 2 pins on the diagnostics-connector found by the fuse-box by the steering wheel.
Can anyone tell me what pins to shorten, and other usefull information about this?
Thanks in advance,
Frank Hansen.
Richard Gallagher
Unread post by Richard Gallagher »
Firstly unless yours is one of the very first Xantias then it will not have a 2 pin connector.
Up until roughly the introduction of the MK2 Xantia they had a 30 pin connector in with the fuses where the handbooks are kept, Mk2s then went onto a 16 pin connector. If either of these connectors are fitted then the paperclip method won't work, you need a professional code reader.
spinner
Oh, ok.
Well, mine is a '95 Xantia 1.6i with the Magneti Marelli 8P ECU.
Is has the 30-pin connector, so I guess I'll have to visit my Citroën-dealer then :(
It's just that they want ~£120 to extract the fault codes for me ... I think its kind of expensive, for say max. 15 mins of work :(
Thanks for you reply
Frank Hansen.
bernie
Unread post by bernie »
Are the early petrol Xantii not the same as the later BX GTI?
Seems a shame as my BX had the 2 pin connection and was just a case of a 2 way switch, 2 wires and a croc clip then use the engine management light for the codes.
Seemed so easy and Bob's yer firkin[:D][:D]
jeremy
Unread post by jeremy »
Have a look at Gunsons site - look a bit old for your car.
http://www.gunson.co.uk/acatalog/
Jeremy
pwatson
Unread post by pwatson »
This any good?? I know nowt about them but happened to spot this while browsing
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 52407&rd=1
spinner
pwatson:
I also looked at this item, but by studying the manual (found here: http://www.drapertools.com/draper/external/68079ins.pdf) you'll see that this also mentions the green 2-pin connector found in the engine compartment.
So I don't think it'll work... :(
Frank Hansen.
Richard Gallagher
All of those are for the 2 pin connector.
Are you anywhere near to Iver/Slough/Uxbridge, if so I have got a code reader and can do it for you.
spinner
Thank you for the offer Richard. Unfortunatly I live in Denmark, so I think it'll be cheaper to just take it to the repair shop :)
By the way, I just received this link on mail: http://xantia.rtkmail.ru/files/diags.pdf
saying it should be possible to ground the C3-pin from the 30-pin connector .. Well, I don't know. I remember measuring the voltage on this pin, gave ~13.8V (with engine running) - I'd think it would be 0V, since the Engine Management Light is not on...
Anyways, perhaps I'll give it a try tomorrow, or just take it straight to the shop...
lhm_leak
Unread post by lhm_leak »
It's not possible. My earlier research on this subject indicates that the Xantia ECUs only output "fast" codes and require a serial code reader, which in this country at least, are a total rip-off.
Ahhhh, at least the old bent paperclip works on our temperamental Cavalier...
Stu.
Richard Gallagher
Denmark, lack of observation on my part!!
