Hey,
does anyone know where cabin air filter is placed in new DS4 (2021 and later) and how to change it?
This information is not available in the car manual (crazy).
I’ve looked behind the dash from passanger side but I haven’t seen it there like it’s placed in VW cars.
Manual only describes air filter but it’s filter for the engine (I thinkg) accesible from engine bay.
DS4 2021 and later - cabin air filter - replacement
- x 6398
Re: DS4 2021 and later - cabin air filter - replacement
It's not shown in the owner manual because it's considered a service item undertaken by the garage at a certain service interval.
It's not located internally, which I suspect is where you've been looking. It's accessed from under the bonnet upper right hand side (UK Driver's side). You'll need to remove the trim as shown...
... to get to get to the pollen filter cover below:
Thank You very much, that helps me a lot.
I want to install na AMP behind the glove box and I was worried if it will obstruct replacing of this filter
I've checked it personally and Cabin Filter for DS 4 2021 and later is located at the passenger footwell after dismounting the cover below the glovebox.
- x 6398
I think I checked under Citroen and not DS, sorry about that.
