Pressure regulator leaking
Dedicated to owners of Citroen GS and GSA models.
Wollop
x 4
Unread post by Wollop »
There's a small leak from the release valve/screw/bolt on our pressure regulator. I don't want to over tighten for fear of stripping the thread.
Is there a simple solution or trick that I am missing? I think it may be a 'ball and cup' type of seal but don't really know.
Any advice including advice to live with it???
x 1438
Re: Pressure regulator leaking
Unread post by xantia_v6 »
Which car?
Wollop
x 4
Sorry, should have said it is a GS.
x 1438
Assuming that it is similar to other Citroen regulators, there should be an O-Ring in a groove on the pressure release screw.
Wollop
x 4
Thanks. Questions, questions, apologies!
I wonder if there is a diagram anywhere? I assume the 'O' ring is down at the other end of the screw, ie not the visible head end? Is there a ball bearing in there also?
I guess I would need to completely de-pressurise the system and then see if I can hook the remains of the old 'O' ring out?
Any suggestions much appreciated.
x 1438
See the screw with o-ring and ball to the left of the regulator body.
Armidillo
(Donor 2022)
x 274
Unread post by Armidillo »
Assuming that on the GS you can completely unscrew the pressure release screw with the regulator "in situ", be very careful of the ball bearing. If it makes it's escape it could be very hard to find!
Wollop
x 4
Many thanks for that, very helpful, I will proceed with caution!
Never tried a ginger nut biscuit dunked in LHM, how was it?
I'll now start another 'leak' thread. As you might guess this car is new to me though 30 years ago I was a happy D owner...
x 5648
Maybe a magnet to capture the ball as it exits?
Wollop
x 4
That's an idea, I have a serious magnet. I was toying with the idea of putting a bag over the regulator and trying to undo it with the spanner inside the bag
Wollop
x 4
All sorted, just had to replace the small O ring on the pressure relief screw
Thanks everyone.
