Hi all,
I'm considering getting a set of 205 GTi alloys for my GT (essentially an XS with 5 doors), since the steel rims are past ther peak and let the car down a little.
What I'm wondering is whether the ride will suffer drastically if I fit them. I'm happy to consider the 14" 1.6 or 15" 1.9 rims (obviously the 1.9 ones look nicer!).
Any advice (or offers of wheels for sale!) gratefully received.
Josh
Fitting GTi alloys to non-GTi 205
PowerLee
r_306_XSi
Hi there,
I did exactly this to my 309 - no problem!
Definatly you need the right alloy bolts! (I have a full set if you're interested?) other than that - great fun! I had the 15" alloys on my 309 so I thought the speedo would have been a bit out, but after driving side by side with my mate with us both registering 30mph it seemed that it was still spot on!
The only hiccup I had was when I got a puncture - as obviously the spare was still a 14" steel!!
joshm
Thanks for the replies. If I get a set without bolts I'd definitely be interested in getting hold of some, so I'll be in touch as and when.
My real query, I guess, related to how the car felt with the bigger rims on - I guess the tyres can be changed to keep a similar circumference. I think that the GTi's had diferent suspension settings and were probably better tuned to drive with the big alloys. With my old BMW I noticed a considerable difference in the ability to soak up the bumps when upgrading from 14" steel to 15" alloy - I just wondered if there was a significant change in the feel of the a non-GTi Pug (13" steel) when Gti alloys (15" alloy) were fitted...
r_306_XSi
joshm
MartinR
One problem you may face is....
Fitting the 15" rims with 195/50/15s on them the wheel may rub the inside of the rear arch if your rear beam is not perfect. What i mean is..... if your beam is creaking and on its way out then the wider wheels will show this up immediately, thus wasting your money as you will have to remove the wheels.
Check the rear beam first before you do anything. The wheels should be perfectly straight like this |----| if they are like /----| or
|----\ then dont fit the alloy wheels.
You can of course fit 185s to the 15" rims if you think your beam is on its way out.
Incidentally i have 15 of the 14" rims, 14 of which have road legal tread on them, but my guess is that you would like the 15" rims instead.
joshm
r_306_XSi
Hi JoshM,
Sorry - didn't get your email - I think there is some problem with sending email straight from the forum, and I haven't logged on here for a while - I'll look out the bolts for you if you're still interested - only downside is they're heavy so postage may be a bit steep - I'll let you know...
joshm
MartinR
macaroni
