Hi all knowledgeable folk
Has anyone got timing belt removal / installation instructions for a 508 2.0 hdi DW10F
It belongs to a mate of mine, also a member on here., Come to line the crank/flywheel and camshaft but cant find the hole in the flywheel, I have the hole in the engine block behind the starter but cant seem to find one in the flywheel.
I have done dozens of PSA belts and might have to resort to old school and put some marks on it
Steve
DW10F Timing belt
Steve Walsh
- x 515
DW10F Timing belt
- x 6955
Re: DW10F Timing belt
Sorry Steve, I don't have the procedure for this engine.
Steve Walsh
- x 515
No Prob, Old school it is then....Keep me busy on a wet Saturday
Steve Walsh
- x 515
Job done, There is another location hole in the cylinder block below the starter motor for setting flywheel. Rest of it just like the DW10B etc.....
During stripdown also found the Acc Belt has 2 tensioners and both need releasing to enable the belt to come off...
- x 6955
I suspected it may be similar, but didn't want to refer you to procedures that may be incorrect. Thanks for the udpate.
