Activating Superlock and Indexed mirror on X7
yoseff
x 30
Unread post by yoseff »
Is it possible to activate superlock on the X7 or does that need some specific "harware"? In the work C5 (2010 Exclusive) , with 2 clicks on the lock button (FOB) it activates the mode where you cannot open doors from interior . That doesnt happen with the personal one (2011 Exclusive)
I noted that the personal one doesnt have the sensors inside for the alarm. Can that be related?
Something i miss from the Xantia times is the indexed mirror.Can that be activated with lexia?
x 6950
Re: Activating Superlock and Indexed mirror on X7
What you are referring to is called deadlocking.
It is not available on all models and depends on trim and country the vehicle was destined for as in some countries it is not legal. It cannot be 'enabled' as it requires different hardware including the locks.
x 1484
Unread post by xantia_v6 »
Re the mirror indexing, this has been discussed several times
You may find some useful information in viewtopic.php?t=60542
yoseff
x 30
GiveMeABreak wrote: 10 Oct 2023, 10:59 What you are referring to is called deadlocking.
I'm pretty sure both the 2010 and 1011 models (Both 2.0 Hdi 163 and also both Exclusive) were originally for Portugal. The only difference i find between both is the headlights (the newer has the LED DRL) and the newer doesnt't have the volumetric sensors (But i think it has allarm.)
Mine 2004 C5 had superlock, but just needed 1 push on the fob.
I wonder if thats related to the alarm? (That mine 2004 also had the volumetric sensors)
Hope it wasn't just some crazy new rule for Portugal. We do have too any crazy small rules. Miss the old times... :mrgreen:
yoseff
x 30
xantia_v6 wrote: 10 Oct 2023, 15:00 Re the mirror indexing, this has been discussed several times
Dammn European rules... I really miss that Indexed mirror function i had back from the activa.
Now let's see the logic on that: If i need due to the sidewalk , i'll put it down anyway , and i may forget it in that position (it happens quite often) Does it look safer? Those people clearly didn't thought that well...
