Compatible engine codes for Jumpy/Dispatch Spacetourer
anvelopus
Unread post by anvelopus »
Hello, I need a bit of help.
I have a 2016 Citroen Jumpy Spacetourer 2.0 HDi with 150 hp, and I need to replace the engine. The engine code is AHX. I did some research and found out that the engine type is DW10FD. I also found a list of engine codes for DW10FD. My question is: can I use any of those engines? (I have all the attachments, my engine is functional but has a cracked cylinder). Attaching the list of what I believe to be compatible engine codes.
Thank you!
x 6950
Re: Compatible engine codes for Jumpy/Dispatch Spacetourer
There are different variations of these engines.
If you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
