Dear Experts
re our 2010 C5 X7 2.0 HDI Exclusive Tourer, hydraulic clutch
VIN VF7**************[VIN obfuscated, can be read by forum staff]
I have joint-owned this car with my Dad since new; the clutch biting point has always been relatively low, but fine
On returning from holiday, the biting point had dropped a couple of cm, almost to the floor, so I set about bleeding the clutch (a few years overdue!)
Following the attached guidance and using an EasyBleed connected to 15psi, I have bled the filthy fluid from the line, but the biting point remains almost at the floor.
I suspect I need to replace the Slave Cylinder and can see a wide range of variants, including Valeo and LUK; mine looks like the LUK variant.
I can source locally today a VALEO CLUTCH SLAVE CYLINDER, Part No: VLO3100419; any advice on suitability please?
The master cylinder seems to be powerful and fine, as does the clutch. The car only has 50k miles.
Best regards,
RichardC
X7 Clutch
- x 6950
Re: X7 Clutch
I've moved this out of the official parts thread as not really sure if you are asking for a part or not. That thread isn't for technical queries - strictly for part number requests.
In case you want the official Clutch Slave Cylinder Part, see below. I only supply official part numbers, not aftermarket compatibility / cross referencing, but you can use the official part number to source an aftermarket part from this should you wish.
(13) Clutch Slave Cylinder, part: 2182J5, £79.49
RichardC
Re: X7 Clutch
Many thanks for the part number Marc.
It does cross reference with a number of other brands, which should mean they match OEM specs
- x 6950
Re: X7 Clutch
Yes, and you also have the current Citroen price which includes VAT for comparison.
