DS3 Shock Tightening Torque
rtakah
Unread post by rtakah »
VIN VF7**************[VIN obfuscated, can be read by forum staff]
Need the service assembly manual with the tightening torque value of the front shock. More specifically the shock absorber assembly and direction.
Thanks!
x 6950
Re: DS3 Shock Tightening Torque
I've moved this out of the parts thread as it's a technical issue.
We don't supply manuals, but here is the front strut diagram and the tightening torques:
Tightening Torques:
ReferenceDescriptionTightening torque
(1)nut (Damper upper cup) (*)7,5 da.Nm
(2)nut (Suspension strut / Body) (*)7,5 da.Nm
(3)nut (Anti-roll bar rod / Damper ) (*)4,3 da.Nm
(4)Bolt-nut assembly (Suspension strut / Pivot) (*)5,5 da.Nm
(5)Bolt-nut assembly (Front pivot lower ball-joint / Pivot) (*)4 da.Nm
(*) Always to be replaced whenever removed
CAUTION: The "Low Friction" bolts (or nuts) (1), (2), (3) are only for single use and must always be replaced. All re-use is prohibited (risk of breakage). The bolts (or nuts) removed must be thrown away.
