Xantia gear stick
froggy
(Donor 2026)
x 4
Xantia gear stick
Unread post by froggy »
Hi, the top of my gear stick, is breaking up, on my S2 Xantia. just looked on Ebay, there are loads! all slightly different! anybody sourced one recently ? if so , where? thanks in advance Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 8457
Re: Xantia gear stick
This is getting to be a very common problem now, on many PSA vehicles... The one on Daffodil, my erstwhile AX, did the same and became a jigsaw puzzle.. I glued it back together using superglue and araldite but I believe from her current custodian it did not last... But then, I'm rubbish with glue...
The Xantia gear knob is a fit once job as it's secured by barbs and once fitted cannot be successfully removed. It's therefore pointless to go for a second-hand one...
I'd make a wooden one on a lathe. Nicely polished and varnished it'll look good. Some models of Xantia did have wooden ones so it won't be entirely out of character. You could even turn a rebate in it to accept the gear legend disc on top of it :)
froggy
(Donor 2026)
x 4
Cheers Jim.😁
Terry
