Hello there,
I am seeking another help to fix fault that is always coming back after deleting ...
U1802 (error in vehicle speed signal - invalid data received)
Everything is working fine like speed on the DashBoard computer and HeadUp Display so I really don't know where to look to fix this fault. Any ideas where to look ?? Thank You in advance.
Matt
U1802 87 - error in vehicle speed signal
Huskyxantia
- x 928
Re: U1802 87 - error in vehicle speed signal
What car have you got ? This sort of fault could be one of your sensor rings worn more than another .
Husky.
MattSVK
- x 3
Sensor rings situated where?
Anyway I have this problem with "Parking assistance"
Peugeot 508 2.0 133kw GT 2017
Huskyxantia
- x 928
There part of the wheel hubs
Husky.
Huskyxantia
- x 928
Could it be possible that the parking sensors are or have somehow gone to earth ?
Husky.
MattSVK
- x 3
Parking sensors are working fine sometime I have error with one sensor... Later on I will test them with Diagbox to see If every single one is working.
DaveFix
Hi Matt,
I occasionally have this error and a BSI error regarding the immobiliser not unlocking - though I've never noticed an actual problem with either.
Did you find what was causing your error?
Huskyxantia
- x 928
Shot in the dark, when was the cam belt changed ? Is or are the pick up reluctor ring on the bottom pulley gear ok or the crank sensor not breaking down , my theory this detects the spinning of the engine, maybe if these are at fault then it could possibly make another sensor look like its breaking down when really it isnt , just a theory, some of my theory's have for me sometimes giving the answer. It might not be your issue but just thought id pop my head thought here.
Husky.
DaveFix
Good suggestion, though if there was a fault with the device which detects vehicle speed, I would expect lots of other errors including ABS and ESP which I assume also depend on vehicle speed data.
Huskyxantia
- x 928
Possible , but its french ....
Husky.
Pimpex
Hello! I have an issues with parking sensors. Also I check do faults by diabox and got this.
U1802 87
U1805 87 any ideas ?
U1802 87
Wacd
- x 3
Hello, have you been able to find a solution to your problem sir ?Pimpex wrote: 30 Mar 2025, 07:38 Hello! I have an issues with parking sensors. Also I check do faults by diabox and got this.
U1802 87
