U1802 87 - error in vehicle speed signal
MattSVK
x 3
Unread post by MattSVK »
Hello there,
I am seeking another help to fix fault that is always coming back after deleting ...
U1802 (error in vehicle speed signal - invalid data received)
Everything is working fine like speed on the DashBoard computer and HeadUp Display so I really don't know where to look to fix this fault. Any ideas where to look ?? Thank You in advance.
Matt
Huskyxantia
x 862
Re: U1802 87 - error in vehicle speed signal
Unread post by Huskyxantia »
What car have you got ? This sort of fault could be one of your sensor rings worn more than another .
:-D
MattSVK
x 3
Sensor rings situated where?
Anyway I have this problem with "Parking assistance"
Peugeot 508 2.0 133kw GT 2017
Huskyxantia
x 862
There part of the wheel hubs
:-D
Huskyxantia
x 862
Could it be possible that the parking sensors are or have somehow gone to earth ?
:-D
MattSVK
x 3
Parking sensors are working fine sometime I have error with one sensor... Later on I will test them with Diagbox to see If every single one is working.
DaveFix
Unread post by DaveFix »
Hi Matt,
I occasionally have this error and a BSI error regarding the immobiliser not unlocking - though I've never noticed an actual problem with either.
Did you find what was causing your error?
Huskyxantia
x 862
Shot in the dark, when was the cam belt changed ? Is or are the pick up reluctor ring on the bottom pulley gear ok or the crank sensor not breaking down , my theory this detects the spinning of the engine, maybe if these are at fault then it could possibly make another sensor look like its breaking down when really it isnt , just a theory, some of my theory's have for me sometimes giving the answer. It might not be your issue but just thought id pop my head thought here.
:-D
DaveFix
Good suggestion, though if there was a fault with the device which detects vehicle speed, I would expect lots of other errors including ABS and ESP which I assume also depend on vehicle speed data.
Huskyxantia
x 862
Possible , but its french ....
:-D
Pimpex
Unread post by Pimpex »
Hello! I have an issues with parking sensors. Also I check do faults by diabox and got this.
U1802 87
U1805 87 any ideas ?
Wacd
x 3
Unread post by Wacd »
Pimpex wrote: 30 Mar 2025, 07:38 Hello! I have an issues with parking sensors. Also I check do faults by diabox and got this.
U1802 87
Hello, have you been able to find a solution to your problem sir ?
